Author Topic: Why Are 3 Keys White And All Others Grey On Model M  (Read 2723 times)
Offline Dirty Bint
« on: Fri, 23 April 2010, 16:43:14 »
Hi,
What is the reason that there are 3 white keys under the key caps and all others are grey on a model M? The white keys are always in the same place.
Rgds
Dirty Bint
I\'m so filthy, I\'m disgusting.
Offline Mental Hobbit
« Reply #1 on: Fri, 23 April 2010, 16:50:36 »
Been wondering too. The white ones are the nub keys, f, j, and num-5. No clue why they're white though.
Typing on blues.
Offline Rajagra
« Reply #2 on: Fri, 23 April 2010, 16:54:57 »
To help the workers (or even users?) put the caps on the right keys, I'd guess.
Offline ricercar
  • mostly abides
« Reply #3 on: Fri, 23 April 2010, 17:21:38 »
My Lexmark Model Ms have two different colors of keys, as well as two colors of sleeves (some are grey and some are white, lining the post holes of 2-wide keys).
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #4 on: Fri, 23 April 2010, 18:04:39 »
I believe there's also a light blue you're missing...
kishy.ca
Offline itlnstln
« Reply #5 on: Fri, 23 April 2010, 18:17:49 »
Quote from: webwit;175223
You are just jealous of my marble keystems.
I actually like the marbled ones.
Offline didjamatic
« Reply #6 on: Fri, 23 April 2010, 20:02:48 »
Dang, those would look great on an F-key row with clear caps over them.
