Author Topic: [GB] Reborn 60% keyborad (Shipping -check you eamil .)  (Read 68776 times)
Online LightningXI
  • PPD
    • ArtisanMacro
Re: [GB] Reborn 60% keyborad (Shipping -check you eamil .)
« Reply #150 on: Sun, 30 December 2018, 01:51:05 »
Oh looks like they are there too. You can see on the bottom left of the top piece :\
Oh, wow, good eye. That's a real bummer. I hope things can be remediated for you.
Offline glubazoid
« Reply #151 on: Sun, 30 December 2018, 02:27:02 »
The screws for mounting the plate to the top piece left imprints
I have the same issue. Sure, it won’t be seen with caps on, but it’s still an eyesore.
Offline Tsuruya
« Reply #152 on: Mon, 31 December 2018, 20:23:20 »
I have the same problem with mine along with a blotch of uneven ano. The screw tap defect is clearly visible to the bottom wall of the inner top case.
Water will something be done for the affected top cases?
Offline glubazoid
« Reply #153 on: Wed, 02 January 2019, 02:54:50 »
On a side note, can we get the PCB firmware files?
Offline feralfoo
  • Software developer and mech keyboard nut
« Reply #154 on: Thu, 03 January 2019, 01:41:18 »
My silver case arrived today, happy to report no defects. Sexy piece of kit :p
HHKB Pro JP + Hasu controller, Realforce RF87U55G, G60 Retro, QK65
Offline Water lee
« Reply #155 on: Thu, 03 January 2019, 07:24:55 »
Hello orders
i am so sorry have been many days not log in here .
This is my first keyboard design ,and the keyboard are not so Perfect
about screws  is my fault, due to i have place the screw too near :-\
make it better!
Offline Water lee
« Reply #156 on: Thu, 03 January 2019, 08:11:15 »
json and hex .
make it better!
Offline feralfoo
« Reply #157 on: Fri, 04 January 2019, 02:55:40 »
@Water Lee would you mind posting the plate design files? I'd like to get some custom plates cut.
Offline Water lee
« Reply #158 on: Fri, 04 January 2019, 07:02:05 »
For sure .
you eamil address pls pm me
make it better!
Offline matrixzj
« Reply #159 on: Mon, 14 January 2019, 09:02:59 »
Thanks for your kindly support
« Last Edit: Tue, 15 January 2019, 09:02:39 by matrixzj »
Discord:Matrix#6203
HHKB Fanatics
SA/GMK Keycaps Info
Offline Water lee
« Reply #160 on: Mon, 14 January 2019, 23:36:38 »
Laplanoel
this id express cant contact you .please check you phone
make it better!
Offline Water lee
« Reply #161 on: Mon, 14 January 2019, 23:38:30 »
when can i get my replacement ?
already ask people in china ship it out
make it better!
Offline BerserkZz
« Reply #162 on: Wed, 30 January 2019, 16:01:52 »
How do you guys flash and map the pcb? I know it's late cuz I used a bface pcb for this one but I want to reuse the mk60 pcb on another build.
Offline 1Weeb
  • ◕w◕
« Reply #163 on: Thu, 07 March 2019, 22:25:45 »
MAO looks great, screw thread showing on the inner top piece seem to be the only issue but they work fine and can't even see them once built.  :thumb:
214638-0
214640-1
214642-2
214644-3
214646-4
214648-5
214650-6
214652-7
214654-8
Offline Etherealsound
« Reply #164 on: Fri, 08 March 2019, 16:45:29 »
Dam that's clean. I wish I had gotten WKL aha
Offline Tyson
« Reply #165 on: Fri, 26 April 2019, 08:41:56 »
I managed to buy one off of mechmarket and it's getting delivered today. Does anyone know if other 60% PCBs will work with this board? I'd love to get a Zeal60 for this thing! :)
Offline 1Weeb
  • ◕w◕
« Reply #166 on: Fri, 26 April 2019, 14:42:37 »
Should work with most standard 60% but only with mini usb since the wider part of a USB C is a bit too wide to fit all the way inside the hole,
Offline rooney
« Reply #167 on: Sun, 05 May 2019, 17:45:38 »
I know someone who used a zeal60 pcb in the Reborn60 so you should be good.
I was wondering if I am able to use a DZ60RGB with a brass plate in this Reborn60 as well.
Any insight would be awesome, thank you!
« Reply #168 on: Mon, 06 May 2019, 03:23:19 »
It depends on which rev of the Zeal60 PCB. The newest one uses USB C which isn't compatible with this case, I think.
Offline rooney
« Reply #169 on: Mon, 06 May 2019, 03:37:19 »
What do you think of the dz60rgb pcb with the brass plate, would that fit?
Offline Choobies
« Reply #170 on: Mon, 06 May 2019, 19:05:41 »
I use the kbd6x pcb in my Reborn, which uses USB-C.  I had to dremel the housing of the USB-C cable to make it fit through the port of the case, but it works!
Offline Tsuruya
« Reply #171 on: Wed, 15 May 2019, 12:32:38 »
Was anyone able to get the plate files before Waterlee completely dipped from this platform? I'd like the data to have plates cut but Waterlee hasn't responded on pm or mail. If anyone managed to get it from the runner would you mind sharing it? Thanks!
« Reply #172 on: Fri, 02 August 2019, 02:06:03 »
Same, I'd love it if I could get the plate files.
Offline Choobies
« Reply #173 on: Fri, 02 August 2019, 08:36:50 »
That's curious, Waterlee was responding to my intermittent PMs not too long ago.  Anyway, here's the plate file that he shared with me.  He was open about giving it out so it should be okay for me to post it here.
https://www.dropbox.com/s/o9puxfhkxy4r0le/Reborn%2060.DXF?dl=0
