Author Topic: [GB] Reborn 60% keyborad (Shipping -check you eamil .)  (Read 68779 times)
Offline Water lee
Re: [GB] Reborn 60% keyborad (Dark purple comes )
« Reply #50 on: Wed, 15 August 2018, 02:46:01 »
Any color sample for the light blue color? Super interested in that color...
Same as render! :thumb:
make it better!
Offline Water lee
« Reply #51 on: Wed, 15 August 2018, 02:50:01 »
i will sent invoice later make sure you options .
make it better!
Offline Choppersuey
« Reply #52 on: Wed, 15 August 2018, 02:54:26 »
How heavy is the board?
Offline glubazoid
« Reply #53 on: Wed, 15 August 2018, 03:23:07 »
Would like to know as well considering you've got a prototype  ;D
Offline Water lee
« Reply #54 on: Wed, 15 August 2018, 07:36:12 »
make it better!
Offline DJSwayde
« Reply #55 on: Wed, 15 August 2018, 09:00:43 »
Can you edit the original post where it says "layout :split space" into "Split backspace compatible" or something? The wording is super confusing, especially with the available photos.
60%: CannonKeys Bakeneko60
BUILD 1: Black | FR4 plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
BUILD 2: Black | 1upkeyboards π60 (pi60) PCB | 1upkeyboards FR4 plate | Akko Rosewoods | HammerWorks CRP R6 Egyptian Alphas kit & CRP R7 kits (40%, 60%, Spacebars, Stepped Modifiers) keycaps
 | GEONWORKS Frog Mini
Silver | HHKB | 4pplet Steezy60 (Alps) PCB | Custom SS plate | Alps SKCL Yellows | Canon S-14 & S-16S keycaps
| GEONWORKS LAUNCHER60
Silver | Custom PCB | Custom SS plate | Alps SKCL Creams | C.Itoh CIT224F & IBM 5140 keycaps
| LSJ Ares
Silver | Custom PCB | Custom SS plate | Alps SKCL Browns & SKCL Amber | IBM Multistation 5556-CC1 (TW) & P70 (ANSI-US, 06-89) keycaps
 | LZ CLS h
Silver | Custom PCB | Custom SS plate | Alps SKCM Creams | MET Micro Officer 6000 (R315-00) & Zenith Data Systems TurbosPORT 386 keycaps
| MONOKEI Kei R1
Standard Red | Aluminum plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G81-1291SAW & G81-3090SAQ (Schneider) keycaps
| SINGAKBD Unikorn R1
Black | Black aluminum plate | Cherry Retooled Blacks (TX 60g springs) | G80-3485LWNUS (Das Keyboard II) keycaps
| Wangus x KEZEWA Snake60 R2
Sage (re-anodized hot pink) | WKL | Custom PCB | Custom SS plate | NMB "Space Invader" (White one-eye linear [fourth generation]) | NMB RT-101 (NCD) keycaps
 | Weaston GSKT-00-Z
Silver | AEK HHKB | Aluminum plate | Alps SKCL Greens | Apple Extended Keyboard II (M3501, Taiwanese) & Standard Keyboard (M0116, US) keycaps
Pad: KBDFans KBDPAD MKII
Black | FR4 plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G80-3485LWNUS (Das Keyboard II) keycaps
| KBDMania KMAC Pad
Titanium grey | Aluminum plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G81-3090SAQ (Schneider) keycaps
| Leopold FC 210TP
White | Custom PCB | Custom SS plate | Alps SKCL Compact Greens & Alps SKCL Browns | C.Itoh CIT224F keycaps
| Momokai Aurora
Cherry Vintage Blacks (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
Topre: PFU Ltd. HHKB Pro 1 (PD-KB300BN)
hasu Alt USB controller | Topre Realforce 91UDK-G (NG02B0) & Realforce 103UB (SE42B0) keycaps
| PFU Ltd. HHKB Pro 2 (PD-KB400B)
hasu Alt Bluetooth controller | Purple sliders | 35g domes | Stock & Topre Realforce Taiwanese kit (dark gray) keycaps
| PFU Ltd. HHKB Pro 2 Type-S (PD-KB400WS)
4pplet SHKB Lite controller | 25g domes | Topre Realforce 87UW55 (SE08T0), Realforce 91UW (NE0100), Realforce Taiwanese kit (white) keycaps
| Topre Realforce 23U (WC0100)
Cipulot EC23U PCB | Purple sliders | SS plate (modified to allow for 24U) | 25g domes | JUKI Celavi keycaps
 | Topre Realforce 87UW (SE08T0)
Purple sliders | 30g domes | Sony BKE-9400A, MKS-8050, PVE-500, stock keycaps
| Topre Realforce 91 (NE0100)
Cipulot RF R1 8-9Xu PCB | 30g domes | JUKI Celavi & Topre Realforce 108UG-HiPro (YK0100) keycaps
Other: Apple Desktop Bus Keyboard (C658-4081) (CA)
Alps SKCM Oranges & SKCL Lock Cream
| Apple M0110A (US)
Beige | Vortex ViBE (US) (case installed inside) | Custom PCB | Custom SS plate | Alps SKCM Blues | Hewlett Packard HP Portable Vectra CS (US) & R/332 Instrument Controller (US) keycaps
| KUL ES-87
Black | Keygeek Su Color V2s (45g) | MW Heresy (with Gluttony & Envy kits) keycaps
| Zuoya HE30
Black | Hotswap: Keytok Novas / Wooting Lekker Tikken Mediums | Ranked POM keycaps
Collection
Offline Water lee
« Reply #56 on: Wed, 15 August 2018, 10:00:07 »
Yes .i have edit it . :thumb:
make it better!
Offline glubazoid
Offline Water lee
« Reply #58 on: Thu, 16 August 2018, 05:01:33 »
make it better!
Offline Choobies
« Reply #59 on: Thu, 16 August 2018, 06:48:20 »
The base kit comes with a PCB, right?  The form has a bubble option for extra pcb ($40), which sort of makes it seem mandatory.  If you could change that to a checkbox, that would make it clearer.  :)
Offline Water lee
« Reply #60 on: Thu, 16 August 2018, 08:50:33 »
Yes base kit have pcb
i have change checkbox  :thumb:
make it better!
Offline Choobies
« Reply #61 on: Thu, 16 August 2018, 09:48:22 »
Great!  Will the plate support split right Shift?
What's the difference between raw and sandblasted brass weight?  Is it just looks and feel?
Offline Water lee
« Reply #62 on: Thu, 16 August 2018, 10:52:24 »
Support
sand will not easy be oxidation
make it better!
Offline tiydal
« Reply #63 on: Fri, 17 August 2018, 04:40:43 »
Can we buy it without the PCB? :)
Offline Water lee
« Reply #64 on: Fri, 17 August 2018, 11:38:42 »
Sry there was no this options  ;D
make it better!
Offline tiydal
« Reply #65 on: Fri, 17 August 2018, 13:22:36 »
Shame, I'll only be using a different PCB so it will just be wasted money.
It would be great if there was an option to not have the PCB :)
Offline glubazoid
« Reply #66 on: Fri, 17 August 2018, 14:30:27 »
agreed, it’ll move me in the direction of purchasing this if that were the case
Offline DJSwayde
« Reply #67 on: Fri, 17 August 2018, 15:02:18 »
I would prefer this as well, as I also will be using my own PCB.
| LSJ Ares
 | LZ CLS h
| MONOKEI Kei R1
| SINGAKBD Unikorn R1
 | Weaston GSKT-00-Z
| KBDMania KMAC Pad
| Leopold FC 210TP
| Momokai Aurora
| Apple M0110A (US)
| KUL ES-87
| Zuoya HE30
Collection
Offline evoluchanel
« Reply #68 on: Sat, 18 August 2018, 11:04:10 »
I would be using a different PCB as well, would be nice to be able to opt out of it.
Offline tiydal
« Reply #69 on: Sat, 18 August 2018, 13:06:53 »
What date does GB finish? I want to join but cant pay right now.
Offline Etherealsound
« Reply #70 on: Sat, 18 August 2018, 13:14:15 »
it days august 30
Offline tiydal
« Reply #71 on: Sat, 18 August 2018, 13:15:52 »
it days august 30
Ah I didn’t see that, thanks.
Offline Water lee
« Reply #72 on: Mon, 20 August 2018, 11:19:49 »
Yea will close on 30th this month
make it better!
Offline Choobies
« Reply #73 on: Wed, 22 August 2018, 06:34:30 »
What size will the keys on the bottom row be for HHKB layout?
Offline Water lee
« Reply #74 on: Fri, 24 August 2018, 08:11:25 »
Is 1.5U X2 7UX1 1.5Ux2
make it better!
Online LightningXI
  • PPD
    • ArtisanMacro
« Reply #75 on: Fri, 24 August 2018, 11:27:00 »
Isn't it 1u 1.5u 7u 1.5u 1u?
Sent from my mobile using Tapatalk
« Reply #76 on: Fri, 24 August 2018, 12:51:49 »
yeah, that seems like hhkb, what he listed seems like wkl
Offline Water lee
« Reply #77 on: Fri, 24 August 2018, 17:06:25 »
Oh sry I have make a mistake
You are right
make it better!
Offline Water lee
« Reply #78 on: Fri, 24 August 2018, 17:06:54 »
1u 1.5u 7u 1.5u 1u
make it better!
Offline Water lee
Re: [GB] Reborn 60% keyborad (Last two days to join)
« Reply #79 on: Mon, 27 August 2018, 11:27:33 »
last two days to join
make it better!
« Reply #80 on: Mon, 27 August 2018, 18:16:24 »
Welp, I caved in and got one. Cheers
Edit: By the way, does anyone have an example of sandblasted vs raw brass?
« Last Edit: Mon, 27 August 2018, 18:19:20 by Etherealsound »
Offline Water lee
« Reply #81 on: Tue, 28 August 2018, 01:47:57 »
 ID :
Unforgivable
dqu22
fcoury
still not paid the invoice
make it better!
Offline DJSwayde
« Reply #82 on: Tue, 28 August 2018, 12:10:11 »
ID :
Unforgivable
dqu22
fcoury
I sent you a PM regarding my order a few days ago, please respond.
Thanks.
| LSJ Ares
 | LZ CLS h
| MONOKEI Kei R1
| SINGAKBD Unikorn R1
 | Weaston GSKT-00-Z
| KBDMania KMAC Pad
| Leopold FC 210TP
| Momokai Aurora
| Apple M0110A (US)
| KUL ES-87
| Zuoya HE30
Collection
« Reply #83 on: Tue, 28 August 2018, 13:26:28 »
paid.
Offline fine_italian_leather
« Reply #84 on: Tue, 28 August 2018, 14:58:13 »
I joined and paid for a hhkb silver, would it be possible to change my order to a light blue hhkb? thanks
Offline Water lee
« Reply #85 on: Tue, 28 August 2018, 21:09:36 »
Sure
i will change and post google form when GB end :thumb:
make it better!
Offline Water lee
Re: [GB] Reborn 60% keyborad (Last ONE day to join
« Reply #86 on: Tue, 28 August 2018, 21:17:00 »
make it better!
Offline Choobies
« Reply #87 on: Tue, 28 August 2018, 21:18:09 »
I submitted order form earlier today but didn't get an invoice.  No rush, just mentioning it.  :)
Offline Water lee
« Reply #88 on: Wed, 29 August 2018, 01:01:24 »
Will sent soon . :thumb:
make it better!
« Reply #89 on: Wed, 29 August 2018, 09:16:27 »
Hey Water, I don't remember what I put on the form but I just want to make sure that the brass I chose was sandblasted.
Offline Water lee
« Reply #90 on: Wed, 29 August 2018, 22:18:46 »
Yes sandblasted
make it better!
Offline Water lee
Re: [GB] Reborn 60% keyborad (Last two hr to join
« Reply #91 on: Wed, 29 August 2018, 22:20:45 »
ID
Unforgivable
fcoury
i have already cancel the invoice .
make it better!
Offline feralfoo
  • Software developer and mech keyboard nut
« Reply #92 on: Wed, 29 August 2018, 22:43:22 »
@Water lee
I've received a second invoice #0047 after already paying invoice #0044. I did notice #0047 was for a few dollars more so should #0044 be refunded?
HHKB Pro JP + Hasu controller, Realforce RF87U55G, G60 Retro, QK65
Offline Water lee
« Reply #93 on: Wed, 29 August 2018, 23:34:01 »
@Water lee
No worry i have cancel 0047.
« Last Edit: Wed, 29 August 2018, 23:37:24 by Water lee »
make it better!
Offline feralfoo
« Reply #94 on: Thu, 30 August 2018, 03:08:42 »
@Water lee
Champion  :thumb:
Offline Water lee
« Reply #95 on: Fri, 31 August 2018, 21:35:16 »
Gg end :thumb:
make it better!
Offline Water lee
« Reply #96 on: Wed, 05 September 2018, 05:49:56 »
i am sorting orers next week weill sent to factory  :thumb:
make it better!
« Reply #97 on: Wed, 05 September 2018, 08:49:46 »
Sounds great! Here's to a smooth and fast gb!
« Reply #98 on: Thu, 27 September 2018, 12:38:21 »
Any updates on this?
« Reply #99 on: Wed, 10 October 2018, 11:29:41 »
Could we please get an update?
