Author Topic: NIB Realforce 108UBK (var. weight, Japan layout)  (Read 8319 times)
Offline ander
  • I type, therefore I am
« on: Mon, 13 August 2018, 03:00:54 »
NOTE: When I posted this, it was BIN $140. It's now been raised to $200—so not as "great" a find.
Topre Realforce 108UBK Variable Load Keyboard
I believe these usually go for well over $200 (whatever that is in yen, LOL).
« Last Edit: Fri, 17 August 2018, 22:10:08 by ander »
Offline 00
Re: NIB Realforce 108UBK (var. weight, Japan layout) $140 shipped
« Reply #1 on: Mon, 13 August 2018, 03:15:52 »
not bad, can get them for about the same used from japan though
It's like, dude, you gotta re-evaluate
Your perspective and your priorities, because
You started doing this because it was ****ing fun, you know?
It has to be fun
Otherwise, you're just torturing yourself, you know?
You're... you're just stuck inside your own ****ing head
Offline method_
« Reply #2 on: Thu, 16 August 2018, 04:02:02 »
For someone looking just for the keycaps it seems reasonable ?
thock program.
Offline 00
« Reply #3 on: Thu, 16 August 2018, 04:04:03 »
the keycaps are lasered and get absolutely disgusting the moment you touch them
It has to be fun
Offline method_
« Reply #4 on: Thu, 16 August 2018, 07:43:27 »
You mean on all the topre ?
thock program.
Offline nmur
  • ಠ_ಠ
« Reply #5 on: Thu, 16 August 2018, 08:34:21 »
just this realforce
Offline ag36
« Reply #6 on: Fri, 17 August 2018, 14:57:20 »
Only the golden ones were lasered.
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline ander
« Reply #7 on: Fri, 17 August 2018, 22:07:39 »
Huh—the seller has raised the price to $200. I'd hazard a guess they found out what these sorta keebs are worth.
Offline SamirD
« Reply #8 on: Sun, 09 September 2018, 10:57:49 »
Hmmm, I think I have a white/off-white version of this with all Japanese markings.  My only Topre so far because they're expensive!
Offline ander
« Reply #9 on: Mon, 10 September 2018, 03:25:35 »
Yep—Topre = pricey!
