Author Topic: [GB] Lumina GB : Update posted in Comments  (Read 220688 times)
Offline JoeriW
Re: [GB] Lumina - Corian 60% (UPDATE 8/27/18) GB Extended One Week!
« Reply #50 on: Tue, 28 August 2018, 10:28:14 »
How are the sales in Europe looking, any indication how much extra shipping/import costs will be added yet?
What I know from the GB owner(s), they are going to ship keebs to UK. Then they will ship to buyers.
I have not found any information about shipping costs, it was always free.
In a previous comment he said that the shipping costs to the EU proxy will be divided under the EU buyers. So when they get the final numbers and a shipping quote we will get an invoice I assume?
Offline GreenwaldDesigns
« Reply #51 on: Tue, 28 August 2018, 14:33:01 »
We are currently working on some bulk pricing numbers, but nothing has been posted. We should have a good idea on how it will work very soon, and we will post those numbers!
Offline Rubbermilitia
« Reply #52 on: Fri, 31 August 2018, 19:15:27 »
This board is so gorgeous and I love acrylic especially the sound, but I am having SUCH a hard time picking colors lol.
Offline RivieraS
  • Yutop
« Reply #53 on: Sat, 01 September 2018, 09:13:05 »
Hi,I would order the Cameo White one.
But how much the shipping fee to Shanghai?
Can you tell me now? It's important to me
Offline Stagione
« Reply #54 on: Sat, 01 September 2018, 16:32:13 »
How does acrylic sound and feel? Never used an acrylic plate before
« Reply #55 on: Sat, 01 September 2018, 19:33:35 »
Its really the acrylic case that makes the nice sound. Instead of reverberating harshly through metal, the sound of the key switches dissipates in a quiet bassy way.
An acrylic plate is quieter than metal and a little more high pitched.
« Reply #56 on: Sun, 02 September 2018, 13:05:29 »
Hey! If you private message us with your address/zip, we can get you a quote on shipping to Shanghai!
« Reply #57 on: Sun, 02 September 2018, 16:35:58 »
I would recommend Cameo white for sure, as it is the cleanest choice you could go with.
Offline distracteddev
Re: [GB] Lumina - Corian 60% GB CLOSING SEPT 3 @ 11:59 PM eastern!
« Reply #58 on: Sun, 02 September 2018, 19:52:51 »
Any more info you can provide on the PCB? Can't seem to find any info on the Googles
« Reply #59 on: Sun, 02 September 2018, 19:56:39 »
There is not any info on google since it is a new pcb that is launching aside the Lumina GB.
Just a quick rundown:
Type C
Alps Support
RGB Underglow
In Switch Leds(south facing)
Runs QMK
Supports the layouts seen in the product images here: https://www.luminakb.com/product-page/waldo-pcb
Costs $40 in the GB
« Reply #60 on: Sun, 02 September 2018, 20:08:50 »
Thanks for the reply Greenwald! Definitely in on this since I think its the only way I can get close to that glorious thock of my original HHKB while staying away from the feel of cheap/light plastic.
Do you know if the typing sound video in the OP was with the acrylic or brass plate? Love the look of the brass plate but if it re-introduces too much metal reverb then I may want to stay away.
« Reply #61 on: Sun, 02 September 2018, 20:12:47 »
Of course!
As for the video, all the tests were done with the brass plate. The sound it produces will not produce any reverb. The main difference between the acrylic plate and the brass plate is that the acrylic plate will be quieter, but both will provide a nice thock for you, especially if you use SA caps on the board.
« Reply #62 on: Sun, 02 September 2018, 20:41:56 »
Been dying to try SA but pretty hard to find them available. Thinking of just buying some of the SP Lime set they put on sale recently.
« Reply #63 on: Sun, 02 September 2018, 20:43:33 »
If you want to try it out for cheap, r/mechmarket will often have people selling Maxkeys sets for not much at all. Definitely look out, I am sure you can find a set.
« Reply #64 on: Sun, 02 September 2018, 21:39:56 »
Hopefully this is my last question! After reading the IC thread I could not determine if the HHKB top option uses a 6u or 7u spacebar?
Also, I assume if we choose the HHKB top, we would not be able to make use of the split spacebar?
« Reply #65 on: Sun, 02 September 2018, 23:28:06 »
The HHKB top uses 7u spacebar, and yeah you would not really be able to make use of the split spacebar, unless you get creative with the layout you choose for the bottom row.
« Reply #66 on: Mon, 03 September 2018, 00:58:02 »
I did end up going with cameo white and the black acrylic plate, which is going to look amazing with GMK monochrome ;)
Also got a brass plate just in case, not sure which one I'm gonna like more
« Reply #67 on: Mon, 03 September 2018, 00:59:42 »
kbdfans and 1up both have cheap SA sets, full set plus some novelties for 100$.
I also was able to fill a 60% with two grab bag sets from r/mm, and its my fav tbh. People sell grab bags for 30-70$ usually
« Reply #68 on: Mon, 03 September 2018, 01:20:30 »
That is gonna be a SWEET combination! Good choice! And yeah getting multiple plates is always a good idea as well :)
« Reply #69 on: Mon, 03 September 2018, 02:06:25 »
Should I put my vintage black on brass or acrylic? I wonder if anyone has input
Offline oumakavoula
« Reply #70 on: Mon, 03 September 2018, 05:22:20 »
seems so good and tempting but can't get around using a 60%, hoping to see more use of this material in the future  :thumb:
Offline Starius
« Reply #71 on: Mon, 03 September 2018, 07:50:24 »
I'm going with a pretty similar theme as you are.
I'll have Cameo White with Black Aluminum Plate and Base.
This is the keyset I'm going to put on it: https://kbdfans.cn/products/maxkey-black-doubleshot-abs-sa-keycaps
I thought about getting GMK Monochrome for this as well, but I've been spending too much money on keyboard stuff lately and just can't responsibly let myself to pull the trigger on that set right now.
« Reply #72 on: Mon, 03 September 2018, 08:45:48 »
I have that set as well ;) Criminally cheap for a nice full WoB set with some novelties included. Of course I much prefer the feel of my SP SA caps
« Reply #73 on: Mon, 03 September 2018, 09:59:13 »
GMk Monocrhome is a pretty nice set for sure. Goes well with mixing Lumina piece colors.
« Reply #74 on: Mon, 03 September 2018, 11:37:38 »
Some more shots with GMK Muted. Just under 12 hours until the GB Closes!202896-0
« Reply #75 on: Mon, 03 September 2018, 18:18:53 »
Definitely plan to do other layouts with the material!
Offline bard
an update?  :thumb:
Offline Starius
I was wondering if there are any updates on this project as well.
Things still progressing smoothly?
Offline JoeriW
An update would be nice indeed.
Offline Arithmetics
i too would love an update :)
Might as well chime in, I would also love an update. Telestron hasn't posted anything in discord for about a month. Not that I'm worried, he's a cool dude. But I invested more into this board than I ever have before and I'm super excited ;)
Hello all! Sorry for the lack of communication lately, have been busy, and not much on various platforms.
I am happy to say that materials for the cases have arrived at the manufacturer, and machining has begun. Additionally, the Waldo PCBs are almost done production, and will be coming to me in about 2 or 3 weeks.
Will provide pictures of the PCBs and boards soon as I finish the first batch of colors!
Let me know if you have any questions!
Nice! Do you have any ballpark estimate for ship date? Will it be before 2019?
All boards should be delivered before the end of 2019. Ideally would be towards the beginning of December, End of November that things are completely wrapped up.
You mean towards the end of 2018? If not, that's a much longer wait than I was expecting lol
Oh my apologies, I do in fact mean 2018
Offline Shell058
  • sheep sheep sheep
Re: [GB] Lumina GB : Material Arrived, Machining and PCBs Production Started
« Reply #86 on: Fri, 12 October 2018, 03:36:24 »
Awesome to hear that things are going well! I sent an email about a change of address for my order but haven't heard back, is there a better way to contact for that? Can't wait for this board!
« Reply #87 on: Fri, 12 October 2018, 08:26:34 »
Thank you! I will check for your email, I may have missed it.
Offline laserbeamspewpew
« Reply #88 on: Sun, 14 October 2018, 22:44:54 »
I regret the plate and bottom material I ordered. Will there be extras?
« Reply #89 on: Sun, 14 October 2018, 22:54:34 »
IKR why did they have to give us so many options lol. Spent literally like 4 days looking at the gb page trying to decide.
Offline 0hok
« Reply #90 on: Mon, 22 October 2018, 21:29:00 »
Hi I know the boards are more or less in the machining phase, but I’m wondering if there’s any confirmation if hotswap PCBs work okay? My understanding is there was no confirmation either way and was hoping to clarify. Thanks!
Offline Holicalis
« Reply #91 on: Mon, 22 October 2018, 21:56:52 »
Yeah me too lol. I will literally just buy another board if there are extras
Offline Regret
  • I regret nothing
« Reply #92 on: Tue, 23 October 2018, 01:44:10 »
I asked this question before and from what I remember, it's not officially supported since this is a sandwich mount and as a result there won't be any mounting points to keep the pcb in place except for the tension of hot swap sockets. If that is ok with you there is no reason you can't use hotswap as long as usb port location matches. Again this is what I remember, but I may be wrong.
No.2 Rev.1 | Gat Black Inks | OG Dyesubs \\ No.1/65 Silver & Brass | Retooled Cherry Blacks | GMK Coniferous \\ Ai03 Lunar | SKCM Blues | AEK \\ Aeryx Aegis 1800 | C3 Tangerines | GMK WoB
Offline Arithmetics
« Reply #93 on: Mon, 05 November 2018, 13:10:09 »
hello. Know im being that annoying person but it's november. any further update? :)
« Reply #94 on: Mon, 05 November 2018, 17:48:06 »
Hi! We will be posting some updates soon, but basically, the boards are being manufactured at the moment. We are doing them in batches, with the first being the Cameo white. Pcbs are also almost done being manufactured and will be arriving soon. Same goes for plates.
Pictures will be coming soon.
Offline Ashardalon
  • Ashkeebs
    • Ashkeebs Lubing Service & Shop
« Reply #95 on: Mon, 05 November 2018, 19:08:03 »
I honestly cannot say how much I regret not going in on this group buy, I hope there will be another round next year, I would love to get one!
Offline Ashardalon
  • Ashkeebs
« Reply #96 on: Sat, 10 November 2018, 14:36:18 »
Is there any possibility of a 65% in the future?
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #97 on: Sat, 10 November 2018, 14:38:56 »
This was answered. I understand it can be hard to find answers on some of these GB threads where a single answer might be buried 30 pages back. But this GB only has two pages.
This is incredibly beautiful and elegant. Any plans to make a 65% version?
Thank you!
We do plan to do a 65% but that will not be some time til mid of next year, well after this one finishes.
Offline Ashardalon
  • Ashkeebs
« Reply #98 on: Sat, 10 November 2018, 16:21:19 »
Thank you!
I'm sorry, I meant to look but forgot since I'm at work. Glad to hear there are plans! I think I'll hold off until then,  that way I can make sure I've got the money! Hopefully we'll see the same level of freedom of choice as with this GB, as it's incredibly refreshing.
Offline KingOfMemes
« Reply #99 on: Mon, 12 November 2018, 11:51:37 »
I'm so hype for this to hit my doorstep :)
