Author Topic: [ENDED] '95 Model M 51G8572 (speaker), $49 shipped  (Read 8691 times)
Offline ander
  • I type, therefore I am
« on: Fri, 17 August 2018, 22:04:01 »
IBM Mechanical "Clicky" Vintage Keyboard Model M
$49.99 + free US shipping
Made for IBM's RS/6000 system; one of the few Model M's with an actual speaker behind the speaker grille. R Ctrl key says "Ctrl/Act". PS/2 compatible. This one's missing a numpad cap, but otherwise looks great.
« Last Edit: Sat, 25 August 2018, 03:55:24 by ander »
Offline SamirD
Re: [ENDED] '95 Model M 51G8572 (speaker), $49 shipped
« Reply #1 on: Sun, 09 September 2018, 10:58:45 »
Hmmm, but would the speaker work with just a regular pc?  If it did, it would drive my wife up the wall even more when I typed on it at night in the bedroom. :D
Offline ander
« Reply #2 on: Mon, 10 September 2018, 03:24:38 »
The speakers in Model M's didn't produce a keypress sound, Samir. The few Model M variants with actual speakers came with IBM UNIX terminal emulators, and made the "beep" sound UNIX systems made when they needed to get the operator's attention. (For example, in a token ring system, if you tried to send data to one of the other terminals on the network and it didn't respond.) One of the olde-timers here explained it to me once.
Offline SamirD
« Reply #3 on: Mon, 10 September 2018, 12:17:51 »
Drat.  And I thought I had found the solution to her complaining about a normal M's sounds.  :))
Offline ander
« Reply #4 on: Wed, 12 September 2018, 19:48:43 »
I wonder if it'd be possible to write an app that used a mic to monitor a keyboard's sound, and played the inverse waveform over a speaker to cancel it out? You know, the way noise-cancelling headphones and helicopters work?
Offline SamirD
« Reply #5 on: Thu, 13 September 2018, 12:03:37 »
I'm sure any noise cancelling algorithm would work well for this.  My idea was to make it beep and click and then she would be okay when I went back to just clicking, haha.  Of course, there is that web site that will make any keyboard sounds like an mech, even a model M--that's always fun to use wtih an actual model M, lol.
Offline ander
« Reply #6 on: Sun, 16 September 2018, 21:55:57 »
Samir—you have 20 1390401s? Or are they various p/n's?
Offline SamirD
« Reply #7 on: Tue, 23 October 2018, 17:36:19 »
I think they are various part numbers, but the same basic Model M made by either IBM or Lexmark but labelled IBM.  Some day I need to round them all up and get them cleaned and pretty, but I'm too busy using them. :D
