Author Topic: Num Lock + Mac = impossible?  (Read 15707 times)
Offline krstf
« on: Sun, 25 April 2010, 08:36:24 »
Hi,
I was wondering if there is any way to turn on the NumLock key on a Model M for instance when using a Mac(Book)?
I have tried all sorts of combinations + looked on the net, but NumLock doesnŽt activate.
Does anyone here have the same problem/ and or a solution to this?
Thanks in advance and have a nice sunday.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #1 on: Sun, 25 April 2010, 08:49:30 »
You can run Windows on the Mac and use Num-Lock there.
Offline krstf
« Reply #2 on: Sun, 25 April 2010, 08:53:57 »
Well that's an option, but not an option for me.
Thanks anywas
Offline krstf
« Reply #3 on: Sun, 25 April 2010, 09:31:41 »
ha! Found a solution! : Key Remap for Mac: http://pqrs.org/macosx/keyremap4macbook/
Thanks for the kind help anyways!
Offline hyperlinked
« Reply #4 on: Sun, 25 April 2010, 09:32:59 »
Quote from: krstf;175758
Does the Num Lock key do anything at all? If the key is getting recognized at all, you might be able to use Keyboard Maestro to remap the key.
Are the Num Lock keys on Model M's the same as the Num Lock keys in current day boards? I don't have any problems at all with my Num Lock keys using "non-Mac" specific keyboards. I don't have a Model M though so I have no idea what might work.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline hyperlinked
« Reply #5 on: Sun, 25 April 2010, 09:36:03 »
Quote from: krstf;175779
Hmm... cool utility! That appears to be basically the equivalent to AutoHotKey that Ripster mentioned. I didn't know about it. I'll have to try it out. Keyboard Maestro doesn't let you remap another key as the Caps Lock key. I don't have caps lock key right now because I use it as a control key.
Offline Specter_57
« Reply #6 on: Sun, 25 April 2010, 09:37:40 »
Can Macs even recognize more than one key input?
Ohhhh..!!  Sorry...that was a Mac mouse I  was thinking of.
Spec_57
Offline krstf
« Reply #7 on: Sun, 25 April 2010, 09:54:49 »
Right now I remapped the numpad keys to the secondary functions (arrows and so on). Gotta play with it a little more and se if there is a possibility to toggle something as NumLock.
Before nothing happened at all when I pressed Num Lock.
IŽll also check wether it is possible to map arrowkeys to j k l i (HHKB style).
Cheers
Offline JBert
« Reply #8 on: Sun, 25 April 2010, 10:20:39 »
Quote from: Specter_57;175785
Spec_57
Oh come on... Now you were just being evil.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline Rajagra
« Reply #9 on: Sun, 25 April 2010, 12:19:08 »
Spec_57
A is for Apple
What's the actual problem that needs to be overcome? Is the number pad unusable because NumLock is off? Is that different to how newer PC keyboards work?
Offline EverythingIBM
« Reply #10 on: Mon, 26 April 2010, 17:52:18 »
Spec_57
Actually, pressing multiple keys really fast on an iMac spikes the CPU usage to 100%.
And using key mapping utilities wastes background resources.
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #11 on: Mon, 26 April 2010, 20:52:15 »
I've been using keyremap4macbook for a while now with no problems or bugs or anything. Glad you're liking it too.
« Reply #12 on: Tue, 27 April 2010, 14:07:05 »
My solution: Get Windows 2000. It beats the living crap out of ANY Mac OS.
Offline ch_123
« Reply #13 on: Wed, 28 April 2010, 13:09:50 »
Not as shiny. Clearly inferior.
Offline Specter_57
« Reply #14 on: Wed, 28 April 2010, 15:17:04 »
re: "...: Get Windows 2000. It beats the living crap out of ANY Mac OS."
Ha!  OS/2 v2.0  would do that...did then does now.....as would/will/does DOS...
Spec_57
Offline ch_123
« Reply #15 on: Wed, 28 April 2010, 15:42:36 »
You must be thinking of a different DOS and OS/2 than I am.
