Author Topic: Should I consider Gateron Clears?  (Read 4790 times)
Offline Sgt_4Leaf
  • Formerly Row009 and StarCraftII
  • I have hands
« on: Sun, 19 August 2018, 19:22:10 »
I'll keep this simple.
My favorite switch is Gateron Red!
For me, it is the most fun/exciting to type on. It sounds great (W/Thick PBT caps). And I type the fastest on it, with less errors than any other switch Iv'e ever tried.
I find that I tend to prefer lighter switches...
So I was wondering if I should consider Gateron Clear switches?
Offline killyou
Re: Should I consider Gateron Clears?
« Reply #1 on: Sun, 19 August 2018, 19:35:24 »
It sound like you are perfectly happy with Gat Red. Do not go into this rabbit hole if you are satisfied with what you have.
Offline Sup
« Reply #2 on: Sun, 19 August 2018, 21:58:21 »
nope if you like 45g switches stay with that weight.
current
Coming soon
Offline Sgt_4Leaf
  • I have hands
« Reply #3 on: Mon, 20 August 2018, 09:58:43 »
Oh well... If you guys insist.
Offline Merranza
« Reply #4 on: Mon, 20 August 2018, 10:17:32 »
I've used MX reds for the last 5 years. I enjoy my reds and I prefer linear to tactile (I have gat browns on one of my board and I like them but not as much as my reds).
Sometimes, I wish my reds would be even lighter so I took the dive and ordered a magicforce 68 with gat clears.
Can't wait to try them and I don't see why you couldn't try them :) If you really want to play it safe, get a hot swappable board and go back to gat reds if you don't like them.
Offline Sgt_4Leaf
  • I have hands
« Reply #5 on: Mon, 20 August 2018, 12:40:14 »
Lets just say that once I went linear (only recently actually)- I stopped using clicky boards altogether.
In fact, I tried out my Cherry MX Blue board (which I used to like a lot) yesterday, just to see how it feels after a while on light linear switches...
It took me by surprise.
It was like torture... Absolutely atrocious!
The way it felt... AND THE SOUND! it nearly gave me a headache. I put it back in the closet, and I don't really see it coming back to my desk. EVER.
I blame the Hedonic Treadmill... A switch I used to swear by became something I don't ever see myself feeling pleasure using.
Offline killyou
« Reply #6 on: Mon, 20 August 2018, 13:21:43 »
If you like linears and you want to step up your game on a relatively inexpensive side try ZealPC Tealios or Kailh BOX Reds. Both of them should be an improvement from Cherry MX Reds.
Offline Sgt_4Leaf
  • I have hands
« Reply #7 on: Mon, 20 August 2018, 15:43:44 »
Which of these two pieces of advice should I listen to?  :))
Offline killyou
« Reply #8 on: Mon, 20 August 2018, 17:15:27 »
I think you already know what you want to do but you are looking for confirmation on the forum. If you are happy I would stay with the reds but if you insist on trying something new then Tealios or Kailh BOX Red.
Offline blighty
« Reply #9 on: Tue, 21 August 2018, 11:11:01 »
If you are referring to trying out 35g linear Gateron clear switches, and like a light, linear switch, go for it.  It was my go-to switch for a year or so, until Cherry released the silent red switches.  I thought about swapping in the 35g springs from the Gat clear switches into the Cherry silent reds, but I find that I make less mistakes typing on the 45g springs.
As for the other switches mentioned above, aren't Tealios just rebranded Gat switches?  Also, don't Kailh BOX switches break non-OEM keycaps?  These questions aren't necessarily reasons not to try the switches, but they would give me pause.
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline killyou
« Reply #10 on: Tue, 21 August 2018, 19:23:12 »
Tealios aren't just rebranded Gat switches and there is new Kailh BOX version already.
