Author Topic: Any tips for good heavy 65% cases for a build?  (Read 2359 times)
Offline Luciqueii
  • 【Luciquell & Co.】
« on: Fri, 24 August 2018, 06:19:57 »
Like the description says I am looking for a 65% case that has a high back and heavy aluminum material case. I did search but could not find any good looking cases.
Someone people out here who wanna help me to build my first MKB? Lets go.
Ty for all of your help in advance!
« Last Edit: Fri, 24 August 2018, 08:14:33 by FLawLesS »
Online LightningXI
  • PPD
    • ArtisanMacro
Re: Any tips for good heavy 65% cases for a build?
« Reply #1 on: Fri, 24 August 2018, 12:06:55 »
TX65
Offline 9999hp
« Reply #2 on: Fri, 24 August 2018, 12:23:42 »
Check out the Zephyr from Zeal; Pretty end-game looking board, supposed to be almost 5lbs. without switches and caps; I think 4.4 without any of that.
Offline nguyenhimself
« Reply #3 on: Fri, 24 August 2018, 22:25:34 »
On the "cheaper" and off-the-shelf side, there's the TADA68 with aluminum case, which I often recommend to newcomers:
The rest you'll have to search for second-hands:
- EXENT.
- Zephyr.
- RAMA M65-A.
- TX65 (I think the seller currently has some left-over stock).
Kinda sorta 65%:
- VA68-M
- Leopold FC660M with an aluminum case from Taobao/AliExpress.
« Last Edit: Fri, 24 August 2018, 22:28:45 by nguyenhimself »
« Reply #4 on: Sat, 25 August 2018, 11:15:47 »
Offline Kevadu
« Reply #5 on: Sat, 25 August 2018, 12:45:11 »
The Tada68 fits all of the OP's requirements and is considerably cheaper than some of the other suggestions here.  That cheapness doesn't mean it's bad though.  It's actually quite well made (and surprisingly heavy).  I think it's a good place to start for most people.
The one thing I don't like about the Tada68 is that it doesn't support split backspace...
