Author Topic: Any good SA keycaps I can buy atm?  (Read 12732 times)
Offline Luciqueii
  • 【Luciquell & Co.】
« on: Fri, 24 August 2018, 06:56:14 »
Are there any good SA keycaps anywhere that I can order? I find it really hard to find SA keycaps to buy. Any color welcome but if you find good looking white or chocolate then +++++
Just hit me up with links or forums maybe I have missed out. :)
Offline oumakavoula
« Last Edit: Fri, 24 August 2018, 07:18:05 by oumakavoula »
Offline Luciqueii
  • 【Luciquell & Co.】
Re: Any good SA keycaps I can buy atm?
« Reply #2 on: Fri, 24 August 2018, 07:26:03 »
Thanks bro, but Aliexpress good quality? HAve you ever bought anything from there? :)
Offline oumakavoula
« Reply #3 on: Fri, 24 August 2018, 07:41:28 »
I bought the SA 9009 from KPRepublic
I like it for the price and availability
people seem to hate it because the caps are warped but when it sits on my keyboard you can't really notice it, at least I don't. It came in a foam tray which is quite convenient
The texture is grainy unlinke SP SA PBT which is smooth, I enjoy both
« Last Edit: Fri, 24 August 2018, 07:44:49 by oumakavoula »
Offline kokokoy
« Reply #4 on: Fri, 24 August 2018, 07:50:16 »
SA Lime SP version still available at PMK
Offline Luciqueii
  • 【Luciquell & Co.】
« Reply #5 on: Fri, 24 August 2018, 08:01:18 »
Link cant find it :/
Offline kokokoy
« Reply #6 on: Fri, 24 August 2018, 08:04:53 »
Oh, PMK/SP - https://pimpmykeyboard.com just browse the site
You have Lime (ABS) or Ice Cap (PBT)
Offline Luciqueii
  • 【Luciquell & Co.】
« Reply #7 on: Fri, 24 August 2018, 08:08:57 »
I ordered this one but will those fit to my khail whtie box switches? :) https://www.aliexpress.com/item/MP-Chocolate-Coloring-123-KEYS-SA-PBT-Keycap-Fonts-Keycap-Cherry-MX-switch-keycaps-for-Wired/32884632297.html?spm=a2g0s.9042311.0.0.3a1a4c4duAnebG
Offline allofthemeat
« Reply #8 on: Fri, 24 August 2018, 09:47:19 »
I've Purchased one SA Carbon knock off set from Aliexpress and the quality is surprisingly nice. The legends are printed, but the plastic is pretty thick and durable. They sound nice too. They obviously aren't SP quality or doubleshot, but they do the trick and arrived quickly and without issue.
Offline Luciqueii
  • 【Luciquell & Co.】
« Reply #9 on: Fri, 24 August 2018, 14:43:34 »
What is this legend you are talking about? I am new so don't laugh xD
Offline oumakavoula
« Reply #10 on: Fri, 24 August 2018, 15:26:16 »
little keycap 101
Offline Absinthe
  • Atreusaurus rex
« Reply #11 on: Sun, 26 August 2018, 03:54:05 »
Francium Pro : MX Brown || B.Mini : Zealio 65 & Zealencios || Atreus62 : Zealio 65 & Zealencios
SA Carbon || SA Dasher || SA Symbiosis 2.0 || SA Retro
