Author Topic: IBM Model F space bar difficulty trying to put it back  (Read 3118 times)
Offline supermario802.1
    • tinkerBOY
« on: Sat, 25 August 2018, 11:13:31 »
I was in a hurry to clean my IBM Model F keyboard and removed all keys including the space bar which I had a bit difficulty in removing it. I suspect I should not have done it but I did it anyway. So is there a way to put it back without disassembling the whole keyboard?
Re: IBM Model F space bar difficulty trying to put it back
« Reply #1 on: Sat, 25 August 2018, 11:54:08 »
Not if it is one of the small ones, an XT or an AT.
There is a long "under-carriage" assembly that goes into the plate like the barrels and installs from below. I use a weighted thread to hold the pieces in place while I press them together.
- D Trump 2026-10-24
    • tinkerBOY
« Reply #2 on: Sat, 25 August 2018, 16:39:07 »
Ok thanks! I guess I'll have to open it up.
Offline ThoughtArtist
« Reply #4 on: Sat, 01 September 2018, 00:27:49 »
The spacebar from hell
