Author Topic: [IC]Chicory-Wireless 40%, with BLE/USB (Update on 9.13)  (Read 36604 times)
Offline prod
« on: Sun, 26 August 2018, 07:00:16 »
2018.09.13 Update
Actually I am a bit depressed because it seems that only a few people are interested in this. But if nothing unexpected happens, I will still start this groupbuy and try my best make sure this GB success.The price will also the lowest I can offer, may around $130 less.
Anyone interested in this can join ALF discord for the latest update of groupbuy info: https://discord.gg/NHYnp8g
More detail Pics of prototype in black.
2018.09.07 Update
Just got a new prototype in BLACK.
2018.09.03 Update
I feel ashamed because I contacted the manufacturer(Both PCB's and Case's) recently, and the price may need to be a little adjusted.
If the price will go up a lot, it will against my will of make a simple 40% Bluetooth keyboard kits, I'll close this IC post at that time.
2018.08.28 Update
This Keyboard kit's price will definite down below $120.
Include:
  • Chicory PCB with MDBT40 BLE Module, support both MX and Alps switch
  • Hollow silvery carbon fiber switch plate,will distinguish among MX+PCB mount stabilizers,MX+Costar,Alps+PCB mount stabilizers and Alps+Alps Costar.So it will have four kinds of switch plate
  • 6061 ALU case(9+1colors for selection),tray mount, manufactured by ALF
  • 1250mAh Li-polymer bettary(MAYBE) The size of bettary slot is 155*40*4mm
  • Screws, tiny clear rubber bump pads, MSS-12D16 power switch, PH-2AW pin header and other accessories if necessary
  • Ability to purchase an extra PCB/Plate
NOT Include:
  • Switches
  • Keycaps
  • Type-C cable
  • Stabilizers or Costar
More PCB info:
  • Atmega32u4, MDBT40 BLE Module etc.(BLE mode can work under macOS or Windows)
  • TMK firmware(YDKB.io)
  • USB-C to USB-A and USB-C to USB-C
  • Split-space
  • Ledmap(https://help.ydkb.io/features/ledmap.html)
  • Charging indicator lights
  • Three optional footprints for power switch(MSS-12D16)
  • Two footprints for battery plug(PH-2AW), can working together, but this case can use only one
About effective Bluetooth range and batterylife:
  • According to my experience, with the 1250mAh Li-polymer bettary, the bettary life can be one months at least every day use.
  • According to the test, the effective Bluetooth range is about 3~4 meters in open area
If you are interested, please join ALF discord for the discussions: https://discord.gg/NHYnp8g
Hey guys, here is a simple wireless 40% keyboard kit,with BLE/USB dual mode.
I'm a crazy 40% keyboards user and collector. I always want to have a simple wireless 40% keyboards, just for typing and easy take outside, with no any other features like RGB or complex shape case.
So here it is. Thanks for the help from my friends.
Actually, "Chicory" is a name of this PCB(the "菊苣" print on PCB means chicory in Chinese), not the keyboard kit. I'm too lazy to give a name to this kit.;D
The PCB desgin by u/yangdigi, use the MDBT40 BLE Module, firmware is TMK(use YDKB.io to program).
Support different layout below
Fot the "simple", I degsin this matching CNC aluminum case with no desgin, no logo, no sign, no weight, just have the battery slot and 4 rubber feet slot,also a little fillet at edge.
This case is manufactured by ALF, and it will provided nine base colors at least.
It also has a special color called Everest White can be choose.
Here is more detail photos, this protoype case is Everest White:
Thanks for your reading.More info will update soon.
« Last Edit: Mon, 01 October 2018, 05:16:22 by prod »
Chicory|YDPv2(BLUP)|BLE40|Daisy|YDPM|YD40w|Golbat
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
Re: [IC]Chicory-A simple 40% Keyboard kit with BLE/USB dual mode
« Reply #1 on: Sun, 26 August 2018, 07:14:23 »
Oh gosh I love this 😁. What price point are we looking at?
Offline fcoury
« Reply #2 on: Sun, 26 August 2018, 09:01:40 »
I am very interested, is there anyway that we could have this ported to QMK? My only concern is that by depending on a website to program your keyboard is a bad thing, if the website ever goes down or something happens with the PCB author we will never be able to reprogram the keyboard.
Would it be something you would consider as part of this GB?
Offline axcoping@gmail.com
« Reply #3 on: Sun, 26 August 2018, 11:17:35 »
how effective is the bluetooth given that it's inside an aluminium case?
Offline Baron
  • oops its me
« Reply #4 on: Sun, 26 August 2018, 17:22:04 »
looks great!
Offline SeedyOne
« Reply #5 on: Sun, 26 August 2018, 20:35:10 »
Very much interested! I know we're at IC phase but I've been looking for a 40% wireless that'll reach 10-12' for my home theater PC. I know range can be an issue with metal cases/interference but if this one pans out, I'll grab two!  :thumb:
Offline prod
« Reply #6 on: Sun, 26 August 2018, 21:46:11 »
I'm not sure, but it will be lower than your expected I guess. ;D
Offline Baron
  • oops its me
« Reply #7 on: Sun, 26 August 2018, 21:50:19 »
any chance for kailh hotswap on this?
Offline prod
« Reply #8 on: Sun, 26 August 2018, 22:07:58 »
3~4 meters away is fine.
I use hollow carbon fiber switch plate instead the common aluminum switch plate to make sure the effective Bluetooth range.
« Last Edit: Sun, 26 August 2018, 22:10:27 by prod »
Offline prod
« Reply #9 on: Sun, 26 August 2018, 22:09:33 »
Unfortunately, this PCB will not support kailh hotswap
Offline prod
« Reply #10 on: Sun, 26 August 2018, 22:15:24 »
I'm so sorry, it will not support use QMK in short time.
Offline SeedyOne
« Reply #11 on: Sun, 26 August 2018, 23:43:34 »
Awesome, count me in!
Offline Bobnaive
when it have GB?
I wanna buy one, it looks great
Offline chouyu
This is the year of bluetooth.
Offline hackqiang
great keyboard!
Offline senter
« Reply #15 on: Tue, 28 August 2018, 08:38:31 »
Hi prod, I'm interested in the ALPS support. Will there be an ALPS plate option?
Offline oldcat
  • 65% is Life
very nice
Offline prod
« Reply #17 on: Wed, 29 August 2018, 08:09:05 »
Yes, it will have MX+PCB mount stabilizers, MX+Costar, Alps+PCB mount stabilizers and Alps+Alps Costar four kinds of switch plate.
Offline prod
Offline prod
Totally!
Offline prod
Offline prod
when it have GB?
Maybe next month.
Offline oldcat
  • 65% is Life
below 120? wow
Offline GreyAmbience
  • I can stop when ever I want
Re: [IC]Chicory-A simple wireless 40% Keyboard kit,with BLE/USB (Update on 8.28)
« Reply #23 on: Sat, 01 September 2018, 01:02:29 »
Def in. Can we sign up for a mailing list?
Offline oldcat
  • 65% is Life
« Reply #24 on: Sat, 01 September 2018, 21:26:46 »
Join ALF discord to discuss Chicory40: https://discord.gg/hkYsVDq
Offline prod
« Reply #25 on: Mon, 03 September 2018, 07:50:18 »
below 120? wow
Unfortunately, I contacted the manufacturer(Both PCB's and Case's), and the price may need to be a little adjusted.
« Last Edit: Mon, 03 September 2018, 07:58:48 by prod »
Offline prod
« Reply #26 on: Mon, 03 September 2018, 07:53:55 »
I am still preparing for start groupbuy, if you have anything want to know, you can join the discord channel what @oldcat post, you will find me there.
« Last Edit: Mon, 03 September 2018, 07:59:41 by prod »
Offline prod
Re: [IC]Chicory-A simple wireless 40% Keyboard kit,with BLE/USB (Update on 9.3)
« Reply #27 on: Thu, 06 September 2018, 21:49:05 »
Offline prod
Re: [IC]Chicory-Wireless 40%, with BLE/USB (Update on 9.13)
« Reply #28 on: Wed, 12 September 2018, 11:27:33 »
2018.09.13 Update
« Last Edit: Fri, 14 September 2018, 03:37:30 by prod »
Offline KetchyKech
« Reply #29 on: Wed, 12 September 2018, 11:45:08 »
Nice. I'm def in -- been waiting for a small form factor bt since gon mobik  :thumb:
Offline Sshimosawa
« Reply #30 on: Wed, 12 September 2018, 12:52:23 »
I am def in for this.
Offline oldcat
  • 65% is Life
« Reply #31 on: Wed, 12 September 2018, 13:06:06 »
Looking really nice!!
Offline prod
« Reply #32 on: Fri, 14 September 2018, 03:35:47 »
Offline prod
« Reply #33 on: Fri, 14 September 2018, 08:51:41 »
Thanks for supporting!
Offline myyrddraal
« Reply #34 on: Fri, 28 September 2018, 11:00:39 »
I am not much into staggered but this one got me. Good job!
