Author Topic: Does PS/2 Soarer's Converter work with PS4?  (Read 2040 times)
Offline bigman7
« on: Sun, 26 August 2018, 15:04:48 »
For use with a mouse and keyboard adapter on the PS4. I know the blue cube can do it but I pay 10 more bucks and can get soarers converter with macro support
Offline Tactile
Re: Does PS/2 Soarer's Converter work with PS4?
« Reply #1 on: Sun, 26 August 2018, 15:21:07 »
As far as I know Soarer's won't do anything for a mouse. For a keyboard: if the Sony has a standard PS/2 port and uses the standard PS/2 protocol a Soarer's converter should work fine.
REΛLFORCE
Offline bigman7
« Reply #2 on: Sun, 26 August 2018, 15:32:53 »
It's actually not for plugging directly into the console but into something called a XIM 4 which is a mouse and keyboard adapter. It works with my Unicomp through USB, wondering if it works with a Soarer's converter
