Author Topic: Split keyboard PCB  (Read 3280 times)
Offline SectorOMEGA
Split keyboard PCB
« on: Tue, 28 August 2018, 03:50:35 »
Im after a split keyboard pcb and found this one https://keeb.io/products/quefrency-60-split-staggered-keyboard?variant=12204552847454  Does any have been using those PCBs? Or can you suggest other ideas for split 60% or 75% but doesn't want to be ortholinear.
Offline nachie
    • KapCave
Re: Split keyboard PCB
« Reply #1 on: Mon, 24 September 2018, 14:19:56 »
There is also the DeltaSplit75 pcb out there if you are looking for something bigger. For an in-between, there is an open source TS65 project here on GH which you can use as well.
AHKB | GSKT-00 | Arya | Båge | Paladin64
