Author Topic: [IC] NL-Bullet Planck's Acrylic Frosted Case  (Read 4615 times)
Offline ozan6661
« on: Mon, 03 September 2018, 06:08:45 »
as part of North Lab studio i want to introduce NL-Bullet with Acrylic Frosted materials
https://imgur.com/a/52oMZ3h
Specs
– High profile case for 40% ortholinear board
– Material: Acrylic Frosted
– Dimension: 238 x 86 x 20 mm
– Plate material: Stainless Steel / Brass
– Plate dimension: 228 x 76 mm
– 7x M2 Hexscrew
– 5x 8 x 2 mm Rubber feet
– 3x 16 x 8 mm Rubber feet
Please note that this case is NOT COMPATIBLE WITH OLKB PLANCK PLATE
Price :
it's will be cheaper than aluminium version.
  ;D ;D ;D ;D
« Last Edit: Mon, 03 September 2018, 06:17:22 by ozan6661 »
Offline jebbra
  • jebbra.net
Re: [IC] NL-Bullet Planck's Acrylic Frosted Case
« Reply #1 on: Mon, 03 September 2018, 06:42:19 »
Just a heads up, North Lab is being run by 3 people with me being the one who active the most on the international forum and do (most) of the design, molenmolen who do the drawing and other technical things, and ozan6661 who do the logistics.
This time, ozan6661 just found a workshop that can do acrylic/polycarb machining and he wants to try it, being busy with other projects now we switch the place and I will be the one who do the work behind the scene.
My personal comment: I think this material will be a fun one since the newest Planck PCB has underglow LED already assembled!
Offline SwordLaker
« Reply #2 on: Mon, 03 September 2018, 16:18:42 »
Why don't you offer an acrylic plate as well for complete transparency?
Offline gwyn
  • ZType Professional
« Reply #3 on: Tue, 04 September 2018, 08:19:12 »
L E Ds
Sent from my SCH-I545 using Tapatalk
Offline te_dulce
« Reply #4 on: Mon, 17 September 2018, 21:16:10 »
consider me interested
