Author Topic: Handwire advice  (Read 2204 times)
Offline SectorOMEGA
Handwire advice
« on: Mon, 03 September 2018, 10:03:37 »
So i have tried cnc my own PCB for four key pad. Well not gonna work as it should be double sided and I cannot solder so fine at both sides and due to that decided to handwire it to the micro pro and use the PCB as a 'case'. Have never been soldering a micro for keyboard so would love an advice. Also i have the led holes drilled so thinking of using them and would I need diodes for the keys. Thank you in advance
« Last Edit: Mon, 03 September 2018, 10:06:28 by SectorOMEGA »
Offline nevin
Re: Handwire advice
« Reply #1 on: Tue, 04 September 2018, 04:34:29 »
nice start.
here are some nice guides about handwiring:
- BrownFox step by step - https://deskthority.net/workshop-f7/brownfox-step-by-step-t6050.html
- All you need to build a custom keyboard - https://matt3o.com/all-you-need-to-build-a-custom-keyboard/
- Hand-wiring a custom keyboard (montage)(video) - https://www.youtube.com/watch?v=MrokZ1afnVg
if you still get stumped, techkeys has small (1, 3, 4 & 6 key PCBs/kits available)
https://techkeys.us/collections/keyboards
good luck, it can be a fun/challenging journey.
Offline SectorOMEGA
Re: Handwire advice
« Reply #2 on: Tue, 04 September 2018, 06:15:56 »
:) Indeed it will be. I have two hardwired KB but with Teensy. But the 4 key is something strange :D also the micro but will give it a try.
