Author Topic: Does anybody know which aftermarket cases fit a GK64 base plate and PCB  (Read 3702 times)
Offline InvisFrames
Just a bit curious. If anyone has a GK64 and moved it to a different case could you tell me which one?
Offline mike-y
Re: Does anybody know which aftermarket cases fit a GK64 base plate and PCB
« Reply #1 on: Mon, 03 September 2018, 19:30:23 »
Most of the standard aluminum 60% cases will work.  I currently have mine in a Tofu case from KBDfans.  I did have a cheap plastic 60% case with the ribs on the bottom that did interfere with the hotswap sockets on the pcb.
but anything that doesn't have the ribs = fits!
Offline D4PP3R
« Reply #2 on: Tue, 11 September 2018, 17:41:56 »
as long as you're willing to sand down some of the front ribs on plastic cases you should be fine with most cases, although the plate that comes with the GK64 causes some problems as it's often too big for cases.
