Author Topic: Realforce R1 vs R2 opinions on the case design?  (Read 12262 times)
Offline Sup
« on: Sat, 08 September 2018, 10:52:45 »
Hello guys i wonder what you guys think of the new designed Realforce boards case design wise.
Am i the only one that dislikes the smaller sized bezel? I think the Realforce 87u big boi top bezel looks nicer and it makes it look like a tank and you can also put a pencil or other stuff on it  :).
What do you guys think of this new design?
Reference pictures
Realforce 87u R2
Realforce 87u R1
« Last Edit: Sat, 08 September 2018, 10:55:20 by Sup »
current
Coming soon
Offline nmur
  • ಠ_ಠ
Re: Realforce R1 vs R2 opinions on the case design?
« Reply #1 on: Sat, 08 September 2018, 11:01:39 »
i have a pretty big soft spot for the uniqueness and charm of the R1 body, and for some reason i don't really like the standard bottom row of the R2. maybe because it adds to its genericness.
i like the R2 though, it looks pretty crisp, and also looks solid. i'm yet to type on one yet however.
Offline zslane
« Reply #2 on: Sat, 08 September 2018, 12:21:44 »
I have Topre keyboards with both cases and I prefer the old school design. As much as I love the Realforce RGB, the one thing I don't love about it is its case (including the fact that it doesn't come in white).
« Reply #3 on: Sat, 08 September 2018, 12:37:19 »
I think the R2 design is better looking but I think the R1 design is better quality.
Offline nguyenhimself
« Reply #4 on: Sat, 08 September 2018, 12:58:31 »
I got to try the R2 when I was in Japan last week. It felt very "gamery". I prefer the old one.
How many plastic cases out there are designed to be full of rounded corners like that? It's way more unique.
Offline Tactile
« Reply #5 on: Sat, 08 September 2018, 13:37:27 »
I'm just an OG kind of guy. I like the old, classic look of the R1 better.
REΛLFORCE
Offline Polymer
« Reply #6 on: Sat, 08 September 2018, 14:11:23 »
Have to agree with most so far...
I didn't like the Realforce look at first because that extra bit on top was meh..but you get used to it and the rounded corners, etc, just look really nice.
The R2 will be great IMO and I'm looking forward to getting one...but it does look very generic.
Offline SBJ
  • Tactile pls
« Reply #7 on: Sat, 08 September 2018, 14:15:50 »
Yeah definitely R1.
I'm an aesthetics kinda guy so it's gotta be pleasing to the eyes as well.
Offline Riverman
« Reply #8 on: Tue, 11 September 2018, 12:27:26 »
I think the newer case looks better, but if it has the quality of the RGB, then it's a step down from the old Realforces.  I don't like how there's so much play in the front of the RGB's case.  You can grab the front edges of teh case and slide it back and forth while the keyboard sits solidly on the desk because the top case is so flimsy.  Personally, I think the Type Heaven has the best combination of styling and build quality of all the Topre keyboards.
Offline Polymer
« Reply #9 on: Wed, 12 September 2018, 05:20:13 »
I don't have an RGB but the normal RF cases can do that too because they're held together with clips...But the actual build quality is excellent.
People get too caught up in lots of things they associate with build quality but don't necessarily mean it has it.
I don't know the exact logic behind the clips...but because the keyboard has some play it can get moved around and has some give which means it isn't going to break.  Keyboards put together without any give will put pressure on where they're held together when moved or banged around a bit...which is why you get stripped screws or screw holes...I don't know if this is really the case but generally there is a reason why a Japanese companies designs something the way they do..it isn't because they're being cheap or lazy...
« Reply #10 on: Wed, 12 September 2018, 05:59:19 »
* Soft edges are friendly edges.
* Glossy plastic on computer peripherals should have died out in 2010.
* Indicator LEDs are best in windows at the corners of keys, or at the centre of the keyboard, or not be present at all.
* 1.5u and 1u mods with 6u space bar is the best bottom row.
* Round keycap corner — round case corner is best. Sharp keycap corner — round case corner is second best. Round keycap corner — sharp case corner looks bad.
The older design was classy and clean. It could perhaps have been improved by making the side borders wider and the top border narrower, but that's it.
« Last Edit: Wed, 12 September 2018, 06:01:14 by Findecanor »
Offline 00
« Reply #11 on: Wed, 12 September 2018, 06:37:22 »
this but the other way around
It's like, dude, you gotta re-evaluate
Your perspective and your priorities, because
You started doing this because it was ****ing fun, you know?
It has to be fun
Otherwise, you're just torturing yourself, you know?
You're... you're just stuck inside your own ****ing head
Offline Lansky
  • Realest motherthocker
« Reply #12 on: Wed, 12 September 2018, 07:02:49 »
I haven't tried the R2, but definitely prefer the design of the R1.
Offline nelamvr6
« Reply #13 on: Wed, 12 September 2018, 08:50:23 »
I like the R2 better. So much that I ordered one as soon as I laid eyes on it!
Keychron Q6 w/ Zeal Clickiez | IBM Model F AT | Leopold FC660C | HHKB Type S
Offline 8Bitterness
« Reply #14 on: Wed, 12 September 2018, 21:50:25 »
For a TKL board I think the new design looks better, the side profile stands out in a nice way. Fullsize the old version looks better because of the Realforce labels.
Offline Altis
« Reply #15 on: Thu, 13 September 2018, 19:40:46 »
They both look quite good. The new one somehow seems both more modern and more classic at the same time, to me.
Is there anywhere selling them?
Offline Sup
« Reply #16 on: Fri, 14 September 2018, 05:51:00 »
I think you can only get them from amazon.jp at the moment.
current
Coming soon
Offline WheresTheSNES
« Reply #17 on: Mon, 17 September 2018, 15:59:40 »
The R1 case is gorgeous.
The R2 makes me want to cry.  So ugly.  Why Topre, why?
Offline kohtachi
« Reply #18 on: Tue, 16 October 2018, 17:33:27 »
r2 silent full size ansi please, anyone know when  they are going to be available in the us?  Already have the R2 PFU kick ass keyboard btw!
FC500RC modded with mod-m switches, PBT Double Shot Keycap Set - Gray/Dark Gray (Tai-Hao), and 008 Buna-N O-Ring, 50A Durometer mod  | REALFORCE R2 PFU Limited Edition  R2TLSABK 45g
« Reply #19 on: Tue, 16 October 2018, 22:48:52 »
r2 is prettier but r2 is better quality
Offline clankgy1
  • Formerly digifiend
« Reply #20 on: Tue, 16 October 2018, 23:04:03 »
I'll look at an R2 when they become more available in the states, but I lub both the R1s i have.
RF87U 55g (damaged)  |  AV3 w/POM Plate  |  Thermal (to be built)  |  ID80v1 (to be rebuilt)  |  Tokyo60
