Author Topic: Introduce Full metal keyboard.  (Read 23143 times)
Offline kant1971
« on: Tue, 27 April 2010, 03:13:24 »
Introduce Full metal mechanical keyboard.
Detail spec is as below.
- Dark Gray body color
- Full alumnium body
- USB
- N key rollover function
- Alumninum Metal frame
- MX brown Switch
- US ASCII 87 Key
- Aluminium metal frame with orange color
- Aluminum keyboard stand
- Laser cut keycap printing
We will make english site and english blog for introduce this keyboard.
Please send mail to me if you have interesting or question.
My email adress is kant1971 at hitel.net
Thank you.
« Last Edit: Tue, 27 April 2010, 03:26:03 by kant1971 »
Offline ch_123
« Reply #1 on: Tue, 27 April 2010, 03:21:25 »
Which switches do they use?
Offline hyperlinked
« Reply #2 on: Tue, 27 April 2010, 03:28:38 »
His post said MX Browns.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline NOMiS
    • http://teamvga.com
« Reply #3 on: Tue, 27 April 2010, 03:31:46 »
Looks sick! Can we get more pics of the back, and inside?
Steelseries Xai
Poker X KBC (Red)
Offline Otterclock
« Reply #4 on: Tue, 27 April 2010, 03:37:12 »
I like the orange. Price check on register 7.
ABS M1|IBM Model M|Lite-On 1788|Cherry G83 6744LUAUS| Logitech S510| Scorpius M10| Cherry 11900.
Offline kant1971
« Reply #5 on: Tue, 27 April 2010, 03:38:16 »
Dear NOMiS..
Sorry. It takes a some time to open inside and bottom part's detail picture.
Because it's now under develooing. It's not fixed.
Anyway, I wil add inside and bottom side picture after all things is fixed.
THank you.
Offline NOMiS
« Reply #6 on: Tue, 27 April 2010, 03:51:01 »
Thanks.
Will they be available in North America?
Steelseries Xai
Poker X KBC (Red)
Offline kant1971
« Reply #7 on: Tue, 27 April 2010, 04:12:31 »
I hope it sells in various area.
But official selling takes a some time. Because we have to aquire some certification each area.
Of course, Direct sending is always possible after officai release.
Offline Otterclock
« Reply #8 on: Tue, 27 April 2010, 04:14:56 »
I like the name. YOU TYPE NOW.
Offline kant1971
« Reply #9 on: Tue, 27 April 2010, 04:30:24 »
Thanks, Otterclock.
I was a big fan to WriteNOW; Mac Wordcessor. :)
Offline ch_123
« Reply #10 on: Tue, 27 April 2010, 05:48:51 »
I assume these will be quite expensive?
Offline skcheng
    • Tenafly Dentistry
« Reply #11 on: Tue, 27 April 2010, 05:59:25 »
Looks nice!!  No chance of getting double shot keys??   I find the orange somewhat distracting, but I could get used to it.  How is the paint applied to the metal outer casing?  Or is it powdercoated?   Will there be a white model??
A higher end Filco Tenkeyless.
skc
Offline didjamatic
« Reply #12 on: Tue, 27 April 2010, 08:20:38 »
I like it, but are you making any without the engraving by the arrow keys?
Offline kriminal
« Reply #13 on: Tue, 27 April 2010, 08:21:50 »
hmm i'll buy this and some doubleshots... mmmm
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline kant1971
« Reply #14 on: Tue, 27 April 2010, 09:43:19 »
To Ch_123
Yes, It will be quite expensive. Material (Full aluminum body) and CNC processing make a unit price serveral times than general plastic body mehanical keyboard.
Please consider it as flagship model in mechanical keybaords. :)
Offline itlnstln
« Reply #15 on: Tue, 27 April 2010, 09:46:03 »
Looks awesome.  What kind of plastic is used in the keycaps?
Offline kant1971
« Reply #16 on: Tue, 27 April 2010, 09:47:48 »
To skcheng.
It use a laser cut keycap not a two shot keycap. We knows double shot keycap has a many merits, but it make a keyboard more expensive. If you like a keyboard, you can change this keycap as other keycap or you can buy dobule shot keycap seperately.
Black color only in first stage. But it can be provided as many color if first stage's result is good. :)
Body color is anodized aluminum.
Offline kant1971
« Reply #17 on: Tue, 27 April 2010, 09:50:46 »
To itlnstin.
It's use ABS mateifial as keycap materials. Yes, most mechanical keyboard use a ABS material, specially in black keycap.
Offline Phaedrus2129
« Reply #18 on: Tue, 27 April 2010, 09:57:21 »
Will the switches be PCB-mounted or plate-mounted?
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline NOMiS
« Reply #19 on: Tue, 27 April 2010, 10:02:54 »
Quote from: Phaedrus2129;176583
Looks plate mounted, considering the orange inside.
Steelseries Xai
Poker X KBC (Red)
Offline itlnstln
« Reply #20 on: Tue, 27 April 2010, 11:17:28 »
Does it come with a full-metal jacket?
Offline kant1971
« Reply #21 on: Tue, 27 April 2010, 11:23:17 »
To Ripster
Yes, Your saying is right. So, I use a 'most' instead of 'every' :)
PBT is rather than ABS in many parts.
But this keyboard is made by one company and also have to consider balance of parts. It's pefect to use all best parts in one keyboard, but it's some impossible in real world.
Anyway, there are a many ways to acquire keycaps.
It's not bad to try switching keycap from one to others. :)
Offline itlnstln
« Reply #22 on: Tue, 27 April 2010, 11:25:51 »
Quote from: kant1971;176612
Unfortunately, in the US and Europe, it's pretty close to impossible (to get new sets such as the KBC ones)
Offline itlnstln
« Reply #23 on: Tue, 27 April 2010, 11:28:57 »
It's a nice 'board.  I think if it had a virtual numpad, I would be all over it.  I wonder what the price will be.  The metal Filco is $300.
Offline itlnstln
« Reply #24 on: Tue, 27 April 2010, 11:41:53 »
Agreed.  That's why I'm thinking this is going to be pretty expensive.
Offline kant1971
« Reply #25 on: Tue, 27 April 2010, 11:43:06 »
To itlnstln,
Thanks for your opinnion.
I think it's possible to provide extra PBT keycap as option.
But anyway, it needs a time to provide it.
« Last Edit: Tue, 27 April 2010, 11:50:56 by kant1971 »
Offline itlnstln
« Reply #26 on: Tue, 27 April 2010, 11:58:19 »
There's a (fairly small) market for keycaps and other accessories here, but we really don't have anybody to sell them to us.  There are a few distributors that might be willing to help (elitekeyboards, The Keyboard Co.), or they could be sold on eBay.  Right now, we have to use brokers to get some products, but that can be cost-prohibitive for some things.
Offline salcan
« Reply #27 on: Tue, 27 April 2010, 12:19:14 »
Looks awesome. Sort of like the dksaver, no?
Lose the orange and I'm in.
Offline itlnstln
« Reply #28 on: Tue, 27 April 2010, 12:24:48 »
To each his own, obviously, but I like the color scheme as it sort of looks like Geekhack.
Offline Rajagra
« Reply #29 on: Tue, 27 April 2010, 12:40:40 »
Looks great, but I'm not fond of blue LEDs.
Any chance of alternative colors?
Offline didjamatic
« Reply #30 on: Tue, 27 April 2010, 13:49:28 »
I like it, glad to see another machined alloy case since the 356cl.  I do wish the logo was smaller or on the edge rather than where it is, but you can't have everything perfect.  And the Orange plate is a nice touch, different than others out there.
Well done.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #31 on: Tue, 27 April 2010, 14:14:02 »
I don't like aluminum keyboards. Steel ones are better since you can stick them to your refrigerator.
Offline itlnstln
« Reply #32 on: Tue, 27 April 2010, 14:14:38 »
Huh?
Offline itlnstln
« Reply #33 on: Tue, 27 April 2010, 14:23:53 »
I find Ms too heavy to mount to the gum under my desk, so I don't know how he'll get it to stick to the fridge.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #34 on: Tue, 27 April 2010, 16:47:26 »
Quote from: webwit;176585
Too bad about the orange. That's just a bit too much.
Hey, you are from NL, you have to love Orange... Orange, and Gouda! :P
A Ghost From The Past
  • ~ BOOO ~
« Reply #35 on: Tue, 27 April 2010, 16:49:01 »
For the board...
Add black anodized aluminum keycaps, remove the logo, and I'll get one, or two!
« Last Edit: Tue, 27 April 2010, 16:53:04 by TheSoulhunter »
Offline kant1971
« Reply #36 on: Tue, 27 April 2010, 16:50:20 »
To salcan,
This keyboard is tenkeyless type or spacesaver type.
it means small keyboard without numberic pad.
Surely, I think orange is not absolute color. But I don't find proper color to inside plate.
I checked black, white, red as internal plate's color. :)
« Reply #37 on: Tue, 27 April 2010, 16:52:18 »
You could do a special "GeekHack" edition board, with the orange plate. It fits the GH color scheme. ;)
Offline kant1971
« Reply #38 on: Tue, 27 April 2010, 16:53:43 »
To Rajagra,
Definitely, it's really good idea. and it's no problem in technical part.
But in first stage, anyway we have to maintain some stock, can send this keyboard where some users want. It's a some difficult in starting point. But surely, it is possible if this keyboard can sells well some. :)
Offline kant1971
« Reply #39 on: Tue, 27 April 2010, 16:57:29 »
Dear Thesoulhunter,
It's a acessory that developed in Korea.
good and luxury items for keyboard. I will consider it, too. :)
Offline kant1971
« Reply #40 on: Tue, 27 April 2010, 16:59:50 »
Dear Phaedrus2129,
It will be a my pleasure if I can prodvide geek hack edition.
Frankly speak, I don't think geekhack color scheme.
Orange internal color is just my choice in this project.
  • ~ BOOO ~
« Reply #41 on: Tue, 27 April 2010, 17:16:45 »
Quote from: kant1971;176715
Dear Thesoulhunter,
Yeah, already own some of this Korean caps...
Unfortunately they neither offer black anodized caps, nor full keysets! :/
Offline kant1971
« Reply #42 on: Tue, 27 April 2010, 17:45:49 »
I think it's not technical issue.
If they can provide full keycap set or other special keycap, they need a minium order quantity. I think making metal keycap is very expensive and difficult work. Just It needs a big investment :) or long wating by customers.
Offline Xuan
« Reply #43 on: Tue, 27 April 2010, 20:23:45 »
Looks nice, sadly it will never get to my region...
Quote from: kant1971;176711
To salcan,
He meant this (check the blue printings):
Offline Otterclock
« Reply #44 on: Wed, 28 April 2010, 00:43:16 »
I really like the orange. Or purple. I wish the board had the slight curve to it like the Filco, though. I like boards with that curve.
Offline armenws
« Reply #45 on: Wed, 28 April 2010, 00:52:33 »
naise
Offline sixty
    • http://deskthority.net
« Reply #46 on: Wed, 28 April 2010, 11:16:29 »
Looks great. I am looking forward to this. It would be great if there will be a bigger "hole" in the metal plate so we can use both style of capslock keys.
Anyway, I don't mind the orange. I am looking forward to this!
Offline ch_123
« Reply #47 on: Wed, 28 April 2010, 13:50:30 »
Quote from: itlnstln;176666
Good things that Model Ms are predominately made of PC or ABS.
Offline Rajagra
« Reply #48 on: Wed, 28 April 2010, 15:23:23 »
Quote from: ripster;176948
I doubt this will go  through FCC or UL.
The FCC requirement "This device must accept any interference received, including interference that may cause undesired operation." is clearly a conspiracy to enable the CIA to monitor our typing, or even to put words into our mouths. I often suspect the CIA is behind the undesirable operation of webwit's keyboard.
Offline kant1971
« Reply #49 on: Wed, 28 April 2010, 16:01:17 »
To tuan,
We can send to any place over the world directly :)
Don't worry.
« Last Edit: Wed, 28 April 2010, 16:11:09 by kant1971 »
