Author Topic: Concrete Keyboard?  (Read 13268 times)
Offline Blitzschnitzel
Concrete Keyboard?
« on: Tue, 11 September 2018, 11:39:46 »
What do you guys think? Should be relatively simple to make with a silicon cast. Will definitely not slide around on your desk. :D
EDIT: Updated the picture
« Last Edit: Tue, 11 September 2018, 19:05:42 by Blitzschnitzel »
Offline Techno Trousers
  • ʘ_ಠ
Re: Concrete Keyboard?
« Reply #1 on: Tue, 11 September 2018, 12:24:39 »
Interesting. If it was colored and polished it could look quite nice. But it would chip or break easily if dropped, and might discolor under finger oils and other contaminants (food, etc.). Thinking of how motor oil can easily stain concrete.
Offline pixelpusher
« Reply #2 on: Tue, 11 September 2018, 12:41:25 »
It looks really hard to pick up or move around with those straight sides.   Not my cup of tea, but the idea is interesting.
Offline wishful_cynic
Offline pixelpusher
« Reply #4 on: Tue, 11 September 2018, 12:54:22 »
true, but the OP's design seems far more elegant
Offline AuthenticDanger
« Reply #5 on: Tue, 11 September 2018, 13:07:56 »
Idea 23 has some 60% cases made of concrete, so it's certainly doable.
F Keys belong on the left.
« Reply #6 on: Tue, 11 September 2018, 14:17:31 »
Well, if I color and polish it there would be little point to concrete. I kind of like the gritty texture and maybe some random bubbles in there.
I could put some chicken wire into the cast for strength and some clear matte varnish should help against decoloration.
It would weigh around 2.5 kilos. Maybe some high rubberfeet would make it easier to pick up.
I can't find it do you have a link?
« Last Edit: Tue, 11 September 2018, 14:19:15 by Blitzschnitzel »
Offline ErgoMacros
« Reply #7 on: Tue, 11 September 2018, 16:32:09 »
Today's quote: '...“but then the customer successfully broke that.”
« Reply #8 on: Tue, 11 September 2018, 17:54:59 »
Thanks thats cool. Althoug, I think I would put less gravel in the mix.
I've made a new version. I think if I make a silicone mold I can get away with a small undercut at the front.
EDIT: Put the new Rendering in the first post.
« Last Edit: Tue, 11 September 2018, 19:06:19 by Blitzschnitzel »
Offline ErgoMacros
« Reply #9 on: Tue, 11 September 2018, 18:08:36 »
Yes, like the new one better!
Offline kriminal
« Reply #10 on: Sat, 15 September 2018, 11:08:22 »
What about porcelain?
Sent from my Moto G (4) using Tapatalk
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline FoC_Tow
  • Brokehlicious
« Reply #11 on: Tue, 18 September 2018, 07:21:09 »
Absolutely love it!
Only issues I can see is finding a good way to mount plate/pcb.
One option would be fixing threaded inserts in the mold, wich will become enclosed in concrete when pouring the case.
Another option to consider would be cutting plates with an concrete anchoring/reinforcing frame around the actual plate.
This way the hole plate could be enclosed in concrete when pouring, creating a single piece case/plate combo.
The case would have to be open on the bottom, but this would make for a very solid case as the plate is locked into place and even adds reinforcement to the case.
really loving the raw concrete look and shape of the case and will be closely watching where this is going!
« Reply #12 on: Tue, 18 September 2018, 15:18:28 »
Yes, I think the easiest way would be using the same brass thread inlays like they are used in plastic cases. Then they get moulded in and they case could still be closed at the bottom.
Offline fpazos
« Reply #13 on: Thu, 27 September 2018, 07:34:45 »
That's one of the craziest and better ideas I have seen around in GH. I searched if someone did the same using resin but I couldn't find anything.
The problem of porcelain is that you have to bake it at a really high temperature and, despite you can use it with a mould, it isn't as liquid as concrete.
EDIT: I found it but I didn't realised that you need a preasure pot as big as the case for doing it. https://geekhack.org/index.php?topic=88062.0
« Last Edit: Thu, 27 September 2018, 07:39:01 by fpazos »
Offline kriminal
« Reply #14 on: Thu, 27 September 2018, 23:56:09 »
Cool, resin looks good though
Offline DiodeHead
« Reply #15 on: Sun, 30 September 2018, 03:57:39 »
oh man those resin cases look good, the big pressure pot probably isn't that big of a problem, Max (from this forum and from youtube make'n'modify) makes one with PVC and since the pressure needed is low, to scale it up from keycaps to keyboard case should be easy. I've seen videos of people doing chambers big enough for a keyboard case and using wood so the tube would not roll off the desk.
glass fiber reinforcement is another option. I hope you like this video.
Offline nevin
« Reply #16 on: Sat, 06 October 2018, 07:19:42 »
Very interesting.
- Finishing.... patina is the new paint.
- Rubber/silicone mat fixed to bottom or large rubber feet to protect desks.
I do like a heavy case, it makes a world of difference. The case for my GH60/pure is one of the cast ones, good weight & dosen't move. A lot of our smaller boards don't have the material to be heavy enough not to move at the slightest bump.
« Reply #17 on: Sat, 06 October 2018, 09:44:59 »
But do be sure to use a sturdy mother-mould to minimise the risk of deformation from the sheer weight of the concrete.
I think a vibrating table could be used to reduce bubbles in a cast before it starts to set.
Offline nevin
« Reply #18 on: Sun, 07 October 2018, 06:23:25 »
Excellent point.
« Reply #19 on: Mon, 08 October 2018, 14:19:45 »
I just got my 3D printer so as soon as i've figured the thing out I can print the first positive form.  :D
Good point. I'm sure Kaupo will sell something that is flexible but not too squishy.
Offline rachel
« Reply #20 on: Mon, 22 October 2018, 04:41:43 »
This is such an interesting project/idea. Looking forward for more updates from you  ;)
Offline 0100010
  • Not Sure
« Reply #21 on: Mon, 22 October 2018, 09:46:35 »
I've been contemplating a concrete "case" to finish up my GH122 (rev 1).  Right now it is just plate with standoffs.  Functional, just not finished.  One of these years...
Offline Darknight00z
« Reply #22 on: Mon, 04 February 2019, 15:05:04 »
Updates?
Offline rinkaan
« Reply #23 on: Tue, 05 February 2019, 20:44:20 »
just a tot,maybe you can use the cheap plastic case thats comes with the chinese kits for gh60 and make a positive and negative mould around the case so the cement moulds around the plastic as a "form" ... that you you get the mounting holes already in place (provided they dont get clogged up)..
Offline JoltFX
« Reply #24 on: Wed, 28 October 2020, 20:57:21 »
Concret60 for sale currently on zFrontier lol
“𝙁𝙖𝙞𝙩𝙝 𝙞𝙨 𝙩𝙝𝙚 𝙗𝙞𝙧𝙙 𝙩𝙝𝙖𝙩 𝙛𝙚𝙚𝙡𝙨 𝙩𝙝𝙚 𝙡𝙞𝙜𝙝𝙩 𝙬𝙝𝙚𝙣 𝙩𝙝𝙚 𝙨𝙠𝙮 𝙞𝙨 𝙨𝙩𝙞𝙡𝙡 𝙙𝙞𝙢.”
