Author Topic: [IC] ALF x Scott — G60 - 60% Retro Dual-mount Dual-mode Keyboard (gb posted)  (Read 89517 times)
Offline Cods
  • Penumbra SA Mark II please?
Re: [IC] G60 - 60% Retro-style Dual-mount Dual-mode Keyboard (Reopen)
« Reply #50 on: Sat, 15 September 2018, 21:23:44 »
Interested! 60%+Arrow keys layout, Bluetooth plus USB C plus QMK is a winner for me.
Model M Industrial, SSK, Unicomp 104, Code TKL MX Green, FC660M MX Green + Clear + White + Grey, FC660C Topre 45g, MagicForce 68 USB and Bluetooth, Whitefox, some optical switch 65% Bluetooth split spacebar thing ... wait, I think I need an intervention. Too late, there’s a couple of new Model Fs on the way.
Too much SA is never enough.
Offline pizza_is_a_lie
  • ISO Master Race
« Reply #51 on: Sun, 16 September 2018, 08:44:13 »
In. HHKB or normal, white or silver. Love it.
Offline oldcat
  • 65% is Life
« Reply #52 on: Sun, 16 September 2018, 10:56:55 »
Personally, 60% ANSI + Arrow cluster is a winner for me too :) haha
Offline befbef
« Reply #53 on: Mon, 17 September 2018, 05:40:08 »
I'm a bit afraid that you want to much for this case.
Every compatibility has disadvantages.
For example the bluetooth integration is something I don't like because it needs a hollow space for battery and I won't use it.
Not sure about the double-mount. Best case it's just a bit more expensive, but perhaps there are other compromises to be made.
The design is so great and I hope it doesn't suffer to much from all this.
I would be happy if it was just an ordinary top-mount (or even tray-mount only) case.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #54 on: Mon, 17 September 2018, 06:55:02 »
I have to agree with this. I don't care a bit for Bluetooth or wireless here. Especially for a board that is meant to be a recreation of something that is classic. Personally I'd rather just get one type of mount and be over with it.
Sent from my mobile using Tapatalk
Offline stoic-lemon
« Reply #55 on: Mon, 17 September 2018, 07:23:27 »
I also don't care for Bluetooth. I embrace the wires!
Offline oldcat
  • 65% is Life
« Reply #56 on: Mon, 17 September 2018, 17:33:44 »
Hey this will be dual mode :) You can always use wires!
Offline Jkush463
dropping a few real nice ones, this is interesting i like how it looks simple.
Offline pixelpusher
Would have a really hard time deciding between white and black.  Love this case.
Offline Quakemz
Hey! I was curious about something. Does the case have standoffs for tray mount? Because I saw this picture of the mounting setup:
https://images-ext-2.discordapp.net/external/UWOQGWHH4f3d4_2EW5hR9wfE83tA0zIwmy4SW5WM8-M/%3Fwidth%3D828%26height%3D444/https/media.discordapp.net/attachments/489587683744677899/491242913058127883/unknown.png?width=746&height=400
Assuming there are standoffs for the tray mount options, why even have the two options? Because the standoffs, even without screws in them, will impede any flex that'd you'd get from the top mount option. Just curious if there was a reason for it?
Offline scottwei
the top mount option is for those who assembing a new board, and the tray mount keeps compitable for those who want to move his assembled boards to this case.
My vision for G60 is that I will make it some kind of a "Standard Platform," not just one keyboard. A "Platform" that we can try using mutiple combinations of PCBs, switches and plates on it. you can easily move your favourite assembled 60% PCB/plate to a G60, change your mini-usb board into type-c via a G60 case, swapping springs to get fresh new experience. I'm hoping a G60 will be a playground for your imagination and creativity with custom keyboards.
Offline hhkbp2
I think the standoffs could be sitting a bit lower than the top mount pcb position so that you could still have most of the flex if you choose top mount.
Offline pixelpusher
Yes, this.  I say put the tray mount posts a bit lower AND THEN... include a very short rubber standoff to add on top of the posts for tray mount.  Adding shock absorbing material on tray mount posts has great effects, and it would solve your dual mount delima by allowing top mount to retain flex and giving tray mount a unique setup for better shock absorption.
I like the idea of accommodating both.  Nice work.
Offline befbef
That's all nice, but i guess that are things most of us are doing with kbdfans cases.
The design is too good to mess it up and I think the price too high to use it as an experimental box.
« Last Edit: Tue, 18 September 2018, 15:00:52 by befbef »
Offline scottwei
so, as hhkbp2 and pixelpusher mentioned. when using top mounted, the PCB won't touch the standoffs, it will be slightly higher than tray mounted. the hollow space for battery is actually not so big, it won't affect the sound of the case when we typing on it.
Offline Quakemz
Ah, I see. Thanks for the clarification!  :thumb:
Offline obertau
Can we get a MAO finish for off-white?
Offline scottwei
On the PCB?
Offline oldcat
  • 65% is Life
Do you mean for the case?
Offline obertau
For the case.
Offline stoic-lemon
At first I thought an off white would be cool, but now, I want red, green, or, blue.
Offline oldcat
  • 65% is Life
For the case.
The white is ALF's Pearl White color. I will share some pictures soon.
Offline chouyu
I can't wait to see it. :cool:
Offline oldcat
  • 65% is Life
Thanks boss!
Offline obertau
What are examples of 60percent boards that would fit the case? Any hotswappable 60percent pcbs that would definitely fit the case?
Offline Kafka
  • i like clean things
Re: [IC] G60 - 60% Retro-style USB/Bluetooth Dual Mode Keyboard (Reopen)
« Reply #75 on: Fri, 21 September 2018, 13:51:26 »
Is there anywhere to see all the possible layouts?
The current plan is to allow layouts similar to XD60, Scott shared this layout image with me. We will update when the new PCB comes in!
Swiss cheese plate :(
Offline oldcat
  • 65% is Life
Will check with Scott about hotswapping!
Offline dantambok
Just got this today! 1.5kg, will try to build it later. Sadly only tray mount  :(
204127-0
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline macken
Damn! That looks solid as a tank.
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
what do you mean only tray mount? no plate?
Offline dantambok
Pare, i mean only since the first proto run was tray mount only. The current version on IC now is a hybrid that supports tray mount as well as top mount  :D
Stuff  I have
100+ GMK sets
Offline dantambok
just built mine today  :D
204179-0
Stuff  I have
100+ GMK sets
Offline oldcat
  • 65% is Life
Wow you got your hands on the V1 G60! Only a handful were made in the private GB.
Offline pr0ximity
Really cool board, not sure if I need something new right now, but if there is a partial plate option I might not be able to resist
Offline oldcat
  • 65% is Life
PCB prototype is being made now.
Offline oldcat
  • 65% is Life
prototype production has started!
Offline distracteddev
Really hope the new PCB supports split space. I really feel like this board could be ideal for it in terms of the smaller form factor and use of additional layers
Offline Pwner
  • soon™
It supports almost any 60% pcbs.
Offline rioc
probs still in ;)
Offline elfick
  • Can I get Colemak and a side of fries with that?
Slightly OT, but is there any chance this will ever be done in a 75%/84-key version?
Offline dr-slump
I'm so stoked for this!!
60% + arrows + ISO  ;D
Will there be an option for OG beige in the future?
Waiting for GMK Miami Dolch ISO . . .
Looking for: Titainium Spacebar 6.25
Offline voight-kampff
Is there an approx. Price?
Sent from my MIX using Tapatalk
Offline oldcat
  • 65% is Life
After the whole prototype is done I think we should be able to give an estimate. Just to give you a reference, the earlier China private GB for the tray mount version was around $250. Unfortunately, the CNC machine time for all the shapes doubles that of making a Doro67, so this kit likely end up between $250 and $300.
Scott will take some videos to show the meticulously crafted shapes for this one.
A must have for me.
Are Hot-swap pcb-s compatible also? Kalih Hot-swap, or holties?
Offline ojrask
  • juuh elikkδs
Replying to get notifications. Super interested.
Current:
Coming up:
IC/GB:
Offline unausgeschlafen
so into this. This is my endgame case!
This is the endgame for me also, although I know there is no such a thing as an endgame. Can't wait for the GB.
Offline oldcat
  • 65% is Life
Image Gallery for R1 version, R2 will be much improved!!
Prototype done soon.
https://www.zfrontier.com/post/detail/5825
Offline lazyfart
Re: [IC] ALF x Scott — G60 - 60% Retro-style Dual-mount Dual-mode Keyboard
« Reply #98 on: Tue, 09 October 2018, 03:00:15 »
Looking good! Love the retro inspiration from the Cherry boards. Hopefully they are built much more sturdy than those though. lol
arrgh, can't wait for this to get it in my hands
:thumb:
