Author Topic: tool to cut my plate?  (Read 2845 times)
Offline Eszett
« on: Sat, 15 September 2018, 11:46:45 »
Hi makers, I need to cut a piece off my prototyping plate which is aluminum, and, unfortunately, it's even powder coated. What kind of tool would you recommend? What I currently have in mind is a miniature angle grinder with diamond saw plate, like the "PROXXON 28650". What do you think? are there better tools, products, methods? It shouldn't be too expensive ( above 100$ ) since I need it only once or twice.
« Last Edit: Sat, 15 September 2018, 11:49:39 by Eszett »
Offline Eszett
Re: tool to cut my plate?
« Reply #1 on: Sun, 16 September 2018, 08:38:42 »
Alright, thanks. Bought a grinding and milling tool from Proxxon (IBS). This will probably do the job.
Offline fpazos
« Reply #2 on: Wed, 26 September 2018, 14:45:34 »
I hope to arrive on time. I don't know if the proxxon would be powerful enough. I have one engraver and it's quite weak. It works well for soft to medium materials as wood, methacrylate, plastics, etc; it's good for precision things. But it almost can't with ebony. You should go for a dremmel or Chinese alike.
Offline JianYang
« Reply #3 on: Sat, 29 September 2018, 03:24:01 »
A rotary tool is not well-suited to cutting alu. A cutting tool like a punch is much better (for creating cutouts for switches). Or metal shears of some sort. On a limb, drilling with a drill-press and filing/sawing to final size can work, and will be much less frustrating than grinding alu.
Sidebar
I prefer grinding titanium to attempting to grind aluminium. Aluminium clogs up the wheel and binds.
« Reply #4 on: Sat, 29 September 2018, 05:42:24 »
I have had two Proxxon rotary tools: too underpowered for drilling holes in 1.5 mm thick T6/6061 aluminium — which is what I suppose is precisely what your plate is. Both overheated and broke on first use. Piece of crap IMHO. Was also more expensive than the Dremel I have now and more unwieldy: I think the springy coiled cable to the separate transformer was shorter than my current Dremel's flexshaft even.
A rotary saw blade might still work for cutting sheet alu though. But I'd rather use a hacksaw — when I can fit it.
I have used a hacksaw to cut plates but it did not work well on long cuts, such as for cutting off a function key row.
A bandsaw or scroll saw might be the best tool, with the right blade of course.
