Author Topic: Help deciphering Cherry G80-3000 serial/article number  (Read 3285 times)
Offline Jackanapes
« on: Tue, 18 September 2018, 05:25:15 »
Looking at a potentially good deal on a cherry board but just want to make sure I know what I'm getting!
Article number: G80-3000LSMGB-0/00
G80-3000LXCYY-Z
L
Keycap printing, typically L for lasered
X
Switch (P = Cherry MX Black, Q = Cherry MX Clear, S = Cherry MX Blue)
C
Connector, typically C for combination PS/2 + USB connector
YY
Layout (EU = US ANSI with Euro sign, GB = UK ISO, DE = German ISO, etc.)
Z
Colour (0 = white, 2 = black)
What I'm gathering here is:
  • MX blue board
  • Laser printed PBT keycaps
  • Year 2000
  • Not sure on the connector
Are the laser printed keycaps much worse quality than the PBT ones?
« Last Edit: Tue, 18 September 2018, 05:32:39 by Jackanapes »
Offline efex
Re: Help deciphering Cherry G80-3000 serial/article number
« Reply #1 on: Tue, 18 September 2018, 05:32:55 »
It depends of the price ;)
And if you don't like the caps, you can change it :)
« Reply #2 on: Tue, 18 September 2018, 07:35:24 »
That should be right. https://deskthority.net/wiki/Cherry_article_numbers
On the G80-3000, laser-printed light grey or two-tone beige keycaps are made of PBT; even the space bar! It is almost always a thin PBT though.
Some older two-tone G80-3000 have lasered keycaps of PBT with thicker walls like most third-party Cherry-profile key sets. These were made before USB and before Windows keys. Before those, Cherry printed the same thick keycap shapes with higher-quality dye-sublimation instead of lasering.
Cherry's lasered black keyboards with white legends are made of POM (Delrin) plastic.
« Last Edit: Tue, 18 September 2018, 07:37:21 by Findecanor »
Offline Jackanapes
« Reply #3 on: Sat, 22 September 2018, 12:29:33 »
Thanks for the detail! Ended up not going for it, it didn't have anything my Filco with MX blues didn't have.
