Author Topic: Solved: DZ60 iso-IT  (Read 2510 times)
Offline Fede Rico
Solved: DZ60 iso-IT
« on: Sun, 23 September 2018, 15:26:11 »
Hello,
I'm building a keyboard with Italian  iso layout (pcb dz60). But I could not configure the "<" (shift ">") key next to the left shift key. Do you have information on how to do it?
thanks
« Last Edit: Sun, 23 September 2018, 15:51:49 by Fede Rico »
Offline fpazos
Re: Solved: DZ60 iso-IT
« Reply #1 on: Tue, 25 September 2018, 11:40:18 »
Hi!! Which keycaps do you plan to use? From other keyboard, Wasd, other?? I'm interested because I am spanish and is a headache to find keycaps for not ansi/uk iso.
