Author Topic: How do you open an Alps switch?  (Read 2247 times)
Offline mr_a500
« on: Fri, 30 April 2010, 11:36:17 »
I may sound like a bit of a loser here, but how do you open an Alps switch... without destroying it? I've got an SGI granite keyboard that's always had a bit of a sticky key (looks like somebody spilled pop on it) and I want to clean out the gunk. It's obviously inside the switch.
(I did do a Google search of geekhack, but only found 3 entries with expired links.)
Offline mr_a500
« Reply #1 on: Fri, 30 April 2010, 12:06:22 »
Excellent. Thanks. That's actually how I thought it worked.
Good thing there was a link to the pictures. The other page had that damn embedded flash again. (which I can't see)
Offline NOMiS
    • http://teamvga.com
« Reply #2 on: Fri, 30 April 2010, 21:45:07 »
I just tilted my keyboard sideways to put the switch back together, without the spring falling out. Was with fukkas though not sure about other flavors.
Steelseries Xai
Poker X KBC (Red)
Offline EverythingIBM
« Reply #3 on: Fri, 30 April 2010, 22:09:49 »
Quote from: ripster;177554
Reminds of a discussion I was having with this guy named Steve...
That's pretty epic...
Although, FOR ONCE, I agree with Stevey. I think flash was way better when Macromedia owned it (Flash MX!) Adobe butchered it.
THE BUTCHER!
Yeah... so what if I'm an oldie gamer. The old games had so much more character in their 2D glory.
Offline mr_a500
« Reply #4 on: Sat, 01 May 2010, 13:03:19 »
Quote from: NOMiS;177710
Yes, exactly. That's how I did it.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #5 on: Sat, 01 May 2010, 13:06:40 »
When I've reassembled ALPS switches, even those inside of keyboards, I find it easier to do upside down (spring stays more upright if it's in the slider instead of on the peg in the bottom half, but metal leaf wants to fall out, so I start to reassemble it sort of sideways then tip upside down once it's at a point where the leaf thing can't fall out)
kishy.ca
Offline mr_a500
« Reply #6 on: Sun, 02 May 2010, 05:59:37 »
I also figured out how to open my finger using an Alps switch.
I was cleaning an Apple Extended II when my finger slipped and the flap on the Alps switch jammed hard under my nail. Blood came gushing out. Man, that ****ing hurt. If I didn't know any better, I'd say that keyboard bit me.
Offline mr_a500
« Reply #7 on: Sun, 02 May 2010, 06:48:02 »
Quote from: webwit;178074
Is the Alps switch ok?
Yes, it's fine... but I nearly "hulked out" and smashed the damn thing. (would have been no loss really, Apple Extended II is crap)
Offline mr_a500
« Reply #8 on: Sun, 02 May 2010, 06:54:53 »
 :blank:
« Last Edit: Wed, 04 July 2018, 12:53:46 by mr_a500 »
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #9 on: Sun, 02 May 2010, 11:20:13 »
Quote from: mr_a500;178084
I was brought up with the philosophy that it's best to sacrifice yourself, rather than damage something. As my father told me when I was 10 while helping carry a fridge down a flight of stairs, "Hands can heal. Walls can't!"
Good thing you live here rather than the US (re: healthcare).
kishy.ca
Offline ch_123
« Reply #10 on: Sun, 02 May 2010, 11:21:33 »
And for just about every other matter as far as I can see.
Offline ricercar
  • mostly abides
« Reply #11 on: Sun, 02 May 2010, 16:18:24 »
Quote from: mr_a500;178081
I nearly "hulked out" and smashed the damn thing./QUOTE]
Wimp.
Been there, done that. Too often. Then I give away the keys and keycaps and make new friends.
