Author Topic: [GB][CLOSED] Klippe+ Round 1  (Read 82002 times)
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« on: Thu, 04 October 2018, 12:05:04 »
https://mekanisk.co/collections/group-buys/products/klippe-plus-mechanical-keyboard-case
Here is the link to the pre order.
3 day DHL shipping, only $35.  Shipping November 2018, no limit on orders. Will be stocked in the "Buy Now"-section later.
Klippe + Mechanical Keyboard Case
PCB
Plate
Ability to customize the case by changing out the Core Plate. You will get accents on the keyboard in the color or material you want. All this for the same price as the original Klippe.
Improvments:
- better fitment by adjusting the screw holes for modern PCBs.
- minor beveled edges to add a slightly more aggressive and unique design signature
- more material on the bottom to make the case even more sturdy and heavier than before
- better fullfillment and quality control
Add a Mirror Finish Brass Plate of your choice for just $20.
Includes premium packaging, screws and rubber feet.
Size: made for 60% keyboards
Compability: standard 60% tray mounted
Material: Aluminium
Treatment: Sandblasted & anodize
« Last Edit: Thu, 30 May 2019, 06:43:46 by LeandreN »
Offline Dreamre
    • kbdlife
Re: [GB] Klippe+ and parts, 60% keyboard
« Reply #1 on: Thu, 04 October 2018, 12:22:32 »
For your international folks, any chance of underdeclaring? I'm looking to purchase 2 PCBs. Thank you.
Offline sleepybrett
« Reply #2 on: Thu, 04 October 2018, 12:28:57 »
No color samples on the product page, no images of all the different plate layouts. How would I know which to buy. Given that the pcb doesn't have split spacebar support it's a non-option for me, but I can't see if any of the plates do... and I can't make a decision on which color case to buy because the only pictured one is, I assume, in the black.
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #3 on: Thu, 04 October 2018, 13:10:24 »
I will try to get some pictures for reference.
sorry about that.
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #4 on: Thu, 04 October 2018, 13:10:54 »
It is usually not a problem if you go through with lettermail.
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #5 on: Mon, 15 October 2018, 06:13:19 »
I am closing this GB soon! Thank you for all the orders, please place your order now if possible.
Offline HerrmannStahl
« Reply #6 on: Tue, 04 December 2018, 07:05:49 »
I missed the GB. Any info, on when this will be stocked on your site / shipped, so I could try to get one from mechmarket?
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #7 on: Mon, 24 December 2018, 06:02:53 »
It has shipped.
There are a handful of cases available that will go up over the new years, however there will be another group buy aswell.
Re: [GB] Klippe+ Round 1
« Reply #8 on: Wed, 26 December 2018, 11:59:27 »
Cool, thanks for the heads up!
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #9 on: Thu, 10 January 2019, 05:35:13 »
