Author Topic: Korean keycap set for Leopold FC660M  (Read 7897 times)
Offline xtec
« on: Sun, 07 October 2018, 02:14:35 »
Hi all,
Does anyone know where I could find a set of korean keycaps for this keyboard? I'm really interested in getting some but haven't had any luck so far.
Sent from my Nokia 6.1 using Tapatalk
Offline ninjacore
Re: Korean keycap set for Leopold FC660M
« Reply #1 on: Mon, 08 October 2018, 09:00:35 »
https://kbdfans.cn/products/enjoypbt-keycaps-dye-subbed-keycap-set-117keys?variant=35672053389
Most enjoypbt sets come w the 1U windows caps you'll need for the fc660m.  The biggest problem you'll have is the additional 2.25U Shift you need.  Your best option might be to just get the Hangul set you want and find a matching 2.25U Shift separate.
Offline xtec
« Reply #2 on: Mon, 08 October 2018, 11:58:04 »
Thanks! Exactly what I was looking for.
