Author Topic: Starcraft 2 beta code with purchase from amazon / gamestop  (Read 5735 times)
Offline elbowglue
« on: Sat, 01 May 2010, 15:50:51 »
This might be old news... but they are sending out beta tester codes by email for people who pre-order Starcraft 2 from Gamestop or Amazon.
One good way to do it at gamestop is this:
Put diablo 3 preorder in your cart (59.99), put starcraft 2 wings of liberty in your cart (59.99) apply code 25off, send your order.  After your order is confirmed, cancel the diablo 3 preorder.  It ended up with Starcraft 2 preorder for me for 49 dollars with free shipping, tax was included (I live in california).
Edit:  Beta code was initially avail, now it's gone thanks!
Time for a good game for your black cherry keyboard eh?
« Last Edit: Sat, 01 May 2010, 19:24:40 by elbowglue »
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline EverythingIBM
« Reply #1 on: Sat, 01 May 2010, 16:20:33 »
That's ironic; I just got a keycode from a friend who I don't know that well. Downloading it...
Time to game on a real IBM-PC.
My System Specifications:
    * Operating system:Windows 2.6.1.7600 ()
    * CPU type:              Intel(R) Pentium(R) 4 CPU 3.40GHz
    * CPU Speed (GHz):3.411
    * System memory (GB):2.999
    * Graphics card model:NVIDIA Quadro FX 3400/4400
    * Graphics card driver:nvd3dum.dll
    * Desktop resolution:1280x1024
    * Hard disk size (GB):93.365
    * Hard disk free space (GB):89.633
It was on my SATA so it interestingly enough ignored my SCSI. AND don't say it, yes I know quadros are not for games, people keep nagging at me about that all the time.
Anyone else getting the beta? I wouldn't mind some AT or solo against a few people. I'm also alpha testing stronghold kingdoms; but that'll be small cheese compared to SC2.
Offline ch_123
« Reply #2 on: Sat, 01 May 2010, 16:42:02 »
AFAIK, it's pretty easy to turn a Quadro into a GeForce by changing some settings in the driver installer. There's no physical difference between them, it's all to do with the driver optimizations.
Offline zwmalone
« Reply #3 on: Sat, 01 May 2010, 17:22:57 »
Hey that wasn't a scam, it worked just fine =P
Can't get enough of them ALPS
Offline Viett
« Reply #4 on: Sat, 01 May 2010, 17:45:48 »
I already have a beta key. Been playing it all week. I figure I'll preorder the game when they actually announce a release date.
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #5 on: Sat, 01 May 2010, 17:47:23 »
Quote from: ripster;177906
Until I scrolled past the neck, I thought this was Steve Perry from Journey. Weird.
kishy.ca
Offline iMav
  • geekhack creator/founder
« Reply #6 on: Sat, 01 May 2010, 19:24:37 »
I preordered from gamestop and have been playing for a few days.
« Reply #7 on: Sat, 01 May 2010, 22:02:11 »
Well I've just prematurely finished my SC2 game. The game crashed on me! Maybe it was because my Quardo FX was running over 80 Celsius, but still. I hate that graphics card actually; SC2 doesn't recognize it.
Bloody programmers, can't prevent a damn game from crashing. I was winning too! Playing as protoss.
« Reply #8 on: Sat, 01 May 2010, 22:09:18 »
There's a screenshot of the temps. Didn't know the CPU was at 55 Celsius, doesn't normally run that hot.
ANYWAYS, the issue is something up with the drivers; windows update made an error and couldn't install the driver, so I had to manually, and everything is still messed up. Ugh....
I'm not getting an nvidia card ever again.
Offline ricercar
  • mostly abides
« Reply #9 on: Sun, 02 May 2010, 16:42:32 »
NVIDIA GPUs are rated FAR higher than 80°C. You have to get over 120°C to start making a good chip fail. If you're having problems at 80°C, you need to consider bad video RAMs, inadequate thermal system, or even a nonThermally-failed GPU (for example drivers as you guess).
In what manner does your video fail? Describe the artifacts or post a screen dump. I should be able to distinguish between bad GPU and bad video RAM for you, if those are your failure points.
bad pixels (shimmering, wrong color, wrong texture) on rendered objects = bad GPU.
bad pixels forming relative to your display positioning = bad RAMs.
« Last Edit: Sun, 02 May 2010, 16:48:59 by ricercar »
« Reply #10 on: Sun, 02 May 2010, 16:53:56 »
Quote from: ricercar;178251
Or how about the screen going black, resetting, and a tray icon telling me the nvidia driver failed? The GPU is fine, it's windows' fault.
Offline ricercar
  • mostly abides
« Reply #11 on: Sun, 02 May 2010, 17:27:56 »
That's the NVIDIA driver. I hate it when I upgrade from a solid driver to a bad one.
Offline iMav
« Reply #12 on: Sun, 02 May 2010, 23:20:08 »
Started playing with the Mac beta client yesterday.  It's been pretty solid for me on my 13.3" MBP.
« Reply #13 on: Mon, 03 May 2010, 01:12:04 »
Quote from: iMav;178348
Well I'm sure you macbook pro wasn't made in 2005 ;)
Offline iMav
« Reply #14 on: Mon, 03 May 2010, 14:37:18 »
Quote from: EverythingIBM;178361
Correct.  My MBP is currently one refresh old.
Regardless, the Mac client appears to be pretty solid thus far.
