Author Topic: [GB] Kyuu 65%  (Read 173335 times)
Offline 8six753o9
Re: [GB] Kyuu 65%
« Reply #150 on: Mon, 03 June 2019, 21:29:20 »
Am I the only one still waiting on shipping?  :(
Offline FunTyme
  • Formerly known as Edrylle
Re: [GB] Kyuu 65%
« Reply #151 on: Mon, 03 June 2019, 21:51:08 »
Most likely not. Quant is still in the process of shipping.
hbcp
Offline AuDiTH
Re: [GB] Kyuu 65%
« Reply #152 on: Tue, 04 June 2019, 12:18:41 »
Still waiting here as well
SSK | AEK64 | TX-CP | HHKB | Acrylic Pearl | Duck Orion V3 | LZ MP | Kyuu Sakura
Offline Egobean
Re: [GB] Kyuu 65%
« Reply #153 on: Mon, 24 June 2019, 15:55:15 »
i would love one of these keyboards!
Offline flying1911
    • Mechlovin' Studio
Re: [GB] Kyuu 65%
« Reply #154 on: Sat, 29 June 2019, 13:34:05 »
Anyone looking to part with their Kyuu? I need a Black Winkey One to save me from the end-game misery :(
Jane V2 | Jane CE | Jane V2 CE | Police | Kaze | KMAC 2 | BRG Haus | Sessantacinque | Ori CLS-2 FE | Dalco 959 Mini | Mechlovin' Unikorn | G81-3100 SAV | Model M SSK
Offline catamscott
Re: [GB] Kyuu 65%
« Reply #155 on: Mon, 08 July 2019, 13:53:26 »
anyone know where to get screws for the case? they look like m3x10mm but the head of the m3 screws i have are just slightly too big to fit in the hole. after opening up the case a few times i can't quite get the screws along the top of the case to screw back in, almost like they're just a little too short to catch the thread so i was going to try and use a slightly longer screw
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
Re: [GB] Kyuu 65%
« Reply #156 on: Mon, 08 July 2019, 14:58:52 »
Having the exact same problem. Looked everywhere, couldn't find solution. Screws that are long enough to reach are not thick enough to fill in the threads. Screws that can reach have such a large head that won't fit into the screw hole. I visited three different Ace Hardware shops, as well as a local Fastenals, but no luck so far. Don't know what to do either.
Offline catamscott
Re: [GB] Kyuu 65%
« Reply #157 on: Mon, 08 July 2019, 16:06:36 »
i found some m2.5 and m2.6 screws online that i'm going to buy and try out. failing that i'm thinking i could try grinding down the heads of some nylon m3 screws, but i'm hoping it doesn't get to that point  :confused:
Offline Quantastrophus
Re: [GB] Kyuu 65%
« Reply #158 on: Mon, 08 July 2019, 17:15:53 »
Ordering a few different kinds of m3 screws to see if any will be suitable replacements. Will keep you all updated.
Offline manzel
Re: [GB] Kyuu 65%
« Reply #159 on: Tue, 09 July 2019, 04:10:57 »
The screws seem to be M3x10 with a PH2 head, so maybe JIS specifications? I also had trouble fitting a normal PH2 bit (or screwdriver) in the holes. Got it to work by extending a PH2 bit with 4 mm hex shank, but proper, longer bits of this form are almost impossible to find.
Offline catamscott
Re: [GB] Kyuu 65%
« Reply #160 on: Tue, 09 July 2019, 14:48:38 »
i was running some errands today and decided to stop by ace hardware to see what they had for screws (only checked home depot before this), and i found some jis m3 screws (forgot what exactly it was called, didn't take a picture since i left my phone in my car) and when i measured the head it looked to be just about 5mm which is what the screw hole diameter on the kyuu looks to be. so i bought four and lo and behold, they work!
looking at the original screw and the new one i got, it looks like the screw diameters are slightly off, but that could just be me. either way, it screws in just fine. here are a few pictures comparing the screws for those interested. https://imgur.com/a/SP1U3N8
Offline catamscott
Re: [GB] Kyuu 65%
« Reply #161 on: Thu, 11 July 2019, 00:58:37 »
went back and got a picture for anyone who was curious
Offline otanishock
  • ファーストラブ
Re: [GB] Kyuu 65%
« Reply #162 on: Sun, 14 July 2019, 16:12:53 »
Just want to follow up. So I got the screws from catamscott (thanks again!) but they were indeed a bit too long as he already mentioned above. I decided to visit another local hardware shop to find some washers. The smallest one they carried was a little bit too big so you'd have to trim the head down. I've posted some pics. Should be able to fill in the gap between the screw's head and the bottom of the screw hole very nicely. If anyone needs help regarding the screws or washers let me know. I can revisit the store and grab a couple more for you.
Offline flatwhitemyth
Re: [GB] Kyuu 65%
« Reply #163 on: Sun, 14 July 2019, 17:59:34 »
I've got no Kyuu, but just gonna drop this here:
https://us.misumi-ec.com/vona2/detail/221000551231/?PNSearch=CSHSMT-SUS-M3-10&HissuCode=CSHSMT-SUS-M3-10&searchFlow=suggest2products&Keyword=CSHSMT-SUS-M3-10
From what I can see, you're dealing with a standard enough M3 x 10 mm length tapped hole, but the head needs to be a smaller diameter. The above fastener is a small-head hex cap screw, diameter is 4.5 mm. No janky fixes FTW.
Offline alisonica
Re: [GB] Kyuu 65%
« Reply #164 on: Sat, 10 August 2019, 16:02:27 »
I'm still waiting too!  ;D
Offline FunTyme
Re: [GB] Kyuu 65%
« Reply #165 on: Sat, 10 August 2019, 16:38:20 »
I hope you get yours soon!
hbcp
Offline alisonica
Re: [GB] Kyuu 65%
« Reply #166 on: Tue, 13 August 2019, 10:07:39 »
Thanks! I just got it today, f**king amazing piece of work. :thumb:
Totally on the Quantrik Hype Train
Hachi, Nana, Roku, Go, Yon, San, Ni, Ichi when?
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: [GB] Kyuu 65%
« Reply #167 on: Tue, 13 August 2019, 10:53:26 »
Hachi already exists, sorta. Private. 65% similar to Kyuu with LZ-RE-esque sides.
Offline AuDiTH
Re: [GB] Kyuu 65%
« Reply #168 on: Tue, 10 September 2019, 21:22:55 »
Been almost a year now and still waiting on shipping...
Offline xoxox1029
Re: [GB] Kyuu 65%
« Reply #169 on: Wed, 11 September 2019, 14:20:26 »
i heard theirs some issues with the kyuu's pcb.... anyone know how to fix or get a new one?
Offline catamscott
Re: [GB] Kyuu 65%
« Reply #170 on: Wed, 11 September 2019, 21:14:01 »
what issues specifically? i haven't had any issues with my pcb, though I would be interested in having another pcb
Offline coffeeshopcoder
Re: [GB] Kyuu 65%
« Reply #171 on: Sun, 15 September 2019, 23:30:31 »
Likewise.. no issues with pcb ... but would like an extra ...
Offline cldskt
  • Wallet and hobby aren't friends
Re: [GB] Kyuu 65%
« Reply #172 on: Sun, 15 September 2019, 23:32:52 »
Would like an extra pcb+plate (fixed stabs spacing ofc) too if anyone is thinking of doing a GB for one ;)
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline newbatthis
Re: [GB] Kyuu 65%
« Reply #173 on: Mon, 16 September 2019, 13:22:46 »
I'd be down for pcb+plate w/ fixed spacebar cutouts as well.
Re: [GB] Kyuu 65%
« Reply #174 on: Tue, 17 September 2019, 18:41:08 »
I have not had anyone contact me regarding PCB issues.
Offline Mcnos
    • GMK Fuyu
Re: [GB] Kyuu 65%
« Reply #175 on: Tue, 17 September 2019, 21:28:19 »
I didn't have any pcb issues, just some fitment problems with the plates and screws is all.
Offline itsundone
Re: [GB] Kyuu 65%
« Reply #176 on: Tue, 17 September 2019, 21:47:42 »
Count me in, I need that too.
Offline Coolbeanz
Re: [GB] Kyuu 65%
« Reply #177 on: Wed, 18 September 2019, 02:36:39 »
Sent you a PM. Thanks!
Offline Solotov
Re: [GB] Kyuu 65%
« Reply #178 on: Wed, 18 September 2019, 06:47:46 »
Any plan for R2?  :-[
Flex is love, flex is life.
Offline Pengu1S1K
Re: [GB] Kyuu 65%
« Reply #179 on: Thu, 19 September 2019, 03:56:13 »
Is there going to be a second round for the Kyuu Sakura Edition??????
Offline dantambok
Re: [GB] Kyuu 65%
« Reply #180 on: Thu, 19 September 2019, 11:01:33 »
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline Keymohh
Re: [GB] Kyuu 65%
« Reply #181 on: Sat, 12 October 2019, 17:30:47 »
Please please please belss us with a revision 2
Offline Incarnius26
Re: [GB] Kyuu 65%
« Reply #183 on: Sun, 13 October 2019, 01:02:59 »
https://www.reddit.com/r/MechanicalKeyboards/comments/dc4vzb/%E4%B9%9D_will_return/?utm_source=share&utm_medium=ios_app&utm_name=iossmf
It’s coming back.
No date and it’s not a GB though so it’ll be hard to get one when it drops
Offline DukeEsquire
Re: [GB] Kyuu 65%
« Reply #184 on: Sun, 13 October 2019, 18:36:56 »
It’s coming back.
I thought it was better than nothing, but I guess beggars CAN be choosers.
Offline Incarnius26
Re: [GB] Kyuu 65%
« Reply #185 on: Sun, 13 October 2019, 20:23:40 »
It’s coming back.
I just stated the two most important things to takeaway from that post. It sucks that it won’t be a GB but I’m just happy it’s rereleasing at all so not really sure what your rudeness is for.
Offline ChickenBear
Re: [GB] Kyuu 65%
« Reply #186 on: Sun, 13 October 2019, 23:13:53 »
Is there a discord server? Thanks!
Offline DukeEsquire
Re: [GB] Kyuu 65%
« Reply #187 on: Mon, 14 October 2019, 07:24:39 »
It’s coming back.
If that’s how you sound happy...
Offline stuey138
Re: [GB] Kyuu 65%
« Reply #188 on: Thu, 24 October 2019, 18:22:07 »
If I keep refreshing the website, will it make the keeb no longer be out of stock? I wanna buy it.
Offline Riskymilk
Re: [GB] Kyuu 65%
« Reply #189 on: Tue, 21 January 2020, 15:48:59 »
Looking to buy a Black Kyuu if anyone is selling one!
Offline DoCallMeKing
Re: [GB] Kyuu 65%
« Reply #190 on: Wed, 20 May 2020, 08:16:17 »
If anyone has an extra Kyuu PCB available, I'd love to purchase it. Just PM me with a price.
Thanks a lot! Have a great day everyone.
Offline catamscott
Re: [GB] Kyuu 65%
« Reply #191 on: Wed, 20 May 2020, 10:07:08 »
i think every kyuu owner is hurting for a pcb lol, to my knowledge there haven't been any aftermarket pcbs compatible with kyuu
Offline Georgeotj
Re: [GB] Kyuu 65%
« Reply #192 on: Wed, 20 May 2020, 10:27:06 »
My pcb order was cancelled, I was gonna donate it to have aftermarket pcb’s created :(
Offline catamscott
Re: [GB] Kyuu 65%
« Reply #193 on: Wed, 20 May 2020, 11:53:32 »
i could be (and often am) way off, but it should just be a 910 pcb but with usb-c instead of mini, i think.
Re: [GB] Kyuu 65%
« Reply #194 on: Thu, 21 May 2020, 19:47:33 »
Thanks for the  responses  everyone. I'll have to look into getting something made.
Do we have plate files available for it anywhere? I'd love to get a new build in it.
Do you know how to get the PCB into DFU? I can't figure out how to get it into reset.
« Last Edit: Thu, 21 May 2020, 19:55:07 by DoCallMeKing »
Offline Georgeotj
Re: [GB] Kyuu 65%
« Reply #195 on: Thu, 21 May 2020, 19:49:36 »
There’s 4 pads on the PCB. You have to short 2 of the pads in a diagonal pattern.
Offline Astrasa
Re: [GB] Kyuu 65%
« Reply #196 on: Thu, 21 May 2020, 19:53:06 »
Alternatively I believe I got mine to reset by holding space + B when plugging the board back in.
Kyuu Proto | Quasi Alice | Duck Viper | Tx87-Se
Re: [GB] Kyuu 65%
« Reply #197 on: Thu, 21 May 2020, 19:55:48 »
Thanks guys. I just got it by holding down escape when plugging it in. I got lucky :)
Offline MiKeyy
Re: [GB] Kyuu 65%
« Reply #198 on: Mon, 04 March 2024, 12:08:26 »
Can anyone please link a suitable replacement screw for the Kyuu badge? Lost mine on rebuild. Thank you!
