Author Topic: keycap on the filco is numberpad is extreme lose..  (Read 1987 times)
Offline FinancialWar
« on: Mon, 03 May 2010, 03:54:50 »
just got my filco number pad today from elitekeyboard....Now here's the problem, the keycaps on the top 2 rows already fell off before I even the box. I was like what the... so I open the box and had look the switch and the under the keycap.
the switch seem to be same as my other filco keyboard, but the "female cross" under the keycap is larger the ones from my filco keyboard, therefore making the keycap lose.
also under the keycap the number pad keycap has " Q M F and a number" while normal keyboard keycap only has a number.
does anyone know here to fix this?
Offline ch_123
« Reply #1 on: Mon, 03 May 2010, 03:57:53 »
You might have a dud, Cherry keycaps usually fit onto the switches quite securely.
« Reply #2 on: Mon, 03 May 2010, 04:03:21 »
Quote from: ch_123;178379
well it's not, i can literally shake the keycaps off...
I don't think these are genuine filco either, I will go home and take some photos tonight and show you guys
Offline ch_123
« Reply #3 on: Mon, 03 May 2010, 04:06:39 »
Either way, send an email off to Brian about it, he should be able to offer you an exchange.
