Author Topic: Code V2b MX Clears  (Read 7020 times)
Offline Alfred96
Code V2b MX Clears
« on: Mon, 22 October 2018, 02:57:50 »
I really like this board and the great thing about it is that it's compatible with most keycap customization. LOVE the switches, great feel. I was scared about people talking about how hard it was changing from blues/browns, but I have since moved on from those switches and use clears 5+ hours a day and don't have any finger fatigue. I can press the keys softer and they still initiate. Anyway, the only gripe I have with this keyboard is the stabilizers on the shift keys and return key. They make a bit of noise and some of things keys are a little noisy and make a very faint 'ping' noise. Unlike the cherry stabilizers, these stabilizers make a faint zing noise and the pinging of the keys is so faint that the only way you can hear it if your ears are very close to the board - so it's not really a problem. But as for the stabilizers, those are a bit louder and are definitely audible.
Re: Code V2b MX Clears
« Reply #1 on: Mon, 22 October 2018, 20:53:09 »
Pinging is a known feature of these keyboards.
Mine pings, but I like the sound.  I usually don't notice it anyway.
Some have also found that the keycaps wear quickly, depending on the length of your fingernails and how oily your fingers are.  Something to be aware of.  Mine are still fine after a couple of years of intermittent use.
