Author Topic: [IC] Minitomic - Update april 17th (happening pretty soon!)  (Read 56611 times)
Offline .
« on: Thu, 25 October 2018, 11:04:20 »
The Minitomic is a 45% staggered keyboard which I've been working on over the last few months.
Before getting a prototype made and opening a group buy, I'd like to get your feedback on the design.
Some information:
- Tray mounted design with 8 mounting points
- High profile one piece anodized aluminium case
- QMK compatible PCB
- Brass or aluminium 1.5mm plate
- European switch spacingtm (19mm)
- USB-C Connector
- Angle of 5 degrees
- Capslock indicator under tab key
- Reset button under left shift key
- Fully designed by me ;D
Anodization colors are to be determined, but will likely include black, silver and dark gray.
The price will hopefully be around 100-150 USD for a kit which includes a case, pcb and plate.
Supported layouts
These are the supported layouts right now, but let me know if you think it's missing something! KLE link
More renders
Thanks to janglad for the render at the top of this post :)
The keyset shown is DSA Just Beige by PrimeKB.
UPDATE 23/03/19
The prototype from china is here! It's looking really good :D
Click the picture for the album.
« Last Edit: Thu, 16 April 2020, 17:32:25 by . »
Offline pngu
  • send noots
Re: [IC] Minitomic (45% staggered keyboard)
« Reply #1 on: Thu, 25 October 2018, 11:05:18 »
nice
Offline William_S_Jones
  • Best Prime Ever!!!
« Reply #2 on: Thu, 25 October 2018, 11:07:19 »
I like it & that’s a great price!
Offline duckboi
« Reply #3 on: Thu, 25 October 2018, 11:08:49 »
19mm spacing will have some keycaps scratch each other, just look at the E6-V2.
There's a reason why that standard is in place.
The m0ar empty you feel,  the m0ar space for Keycaps..
Offline westfoxtrot
    • Cable Car Designs
« Reply #4 on: Thu, 25 October 2018, 11:11:10 »
in for one  ;D
Offline pngu
  • send noots
« Reply #5 on: Thu, 25 October 2018, 11:13:29 »
That seems like an issue specific to that board. All OLKB stuff has 19mm spacing and I personally had a prototype manufactured recently that didn't have any issue like that, too.
Edit: Not to mention the 356mini, but those are tolerances that aren't easily achieved in manufacture.
« Last Edit: Thu, 25 October 2018, 11:17:00 by pngu »
Offline ChrisSwires
« Reply #6 on: Thu, 25 October 2018, 11:23:26 »
45%? Staggered? 7u space option?
Guess I'll maybe be interested perhaps.
Offline nasp
« Reply #7 on: Thu, 25 October 2018, 12:35:29 »
That has to be the most unhelpful and indecisive "interest" in a project!  :p
Offline MikeTheTiger
« Reply #8 on: Thu, 25 October 2018, 12:43:07 »
Color me interested. Looks great!!
"all the numbers or none of them cmon man" -Kokaloo
Offline ChrisSwires
« Reply #9 on: Thu, 25 October 2018, 12:52:21 »
Haha, he knows I'm in. I have a tendency to buy every staggered 40. An unfortunate consequence of being me.
Sent from my Pixel using Tapatalk
Offline long_qt_pie
« Reply #10 on: Thu, 25 October 2018, 12:58:03 »
Nice price point and I like the layout.  Only suggestion would be in one of the split space layouts, to swap the shift and left most FN to have the FN between the two “spaces”
Jetfire | Mech 27 v1 | Mira SE | Singa | Orion 2.5 | Eo87 | Lubrigante | MGA | IBM F XT | AEKII | Lightpad | Exent | Dolphin Rev 2 | F1-8x | Mr Suit
Offline Haaaaaandrew
« Reply #11 on: Thu, 25 October 2018, 14:19:00 »
Looks neat, interested if I have money when it happens. Would love to see the 7u option be 1.5/1.5/7/1.5/1.5 for that sweet, sweet symmetry and to me feels right to use 1.5s with 7u :thumb:
Offline .
« Reply #12 on: Thu, 25 October 2018, 15:46:36 »
Thanks for the feedback so far! I'm glad so many of you like it  :)
I've seen some interest in USB C though, is that something you guys want? I can definitely change that in the design.
« Last Edit: Thu, 25 October 2018, 15:58:11 by . »
« Reply #13 on: Thu, 25 October 2018, 16:14:36 »
Chris, believe I will be joining too!!!
Offline Draic
« Reply #14 on: Thu, 25 October 2018, 17:07:32 »
Remember that only changing the connector will only work for USB-C to A but extra care is needed to ensure USB C to C works
Offline .
« Reply #15 on: Thu, 25 October 2018, 17:15:45 »
Yes, I am aware that I need to add some resistors :)
Offline puddingfarmer
« Reply #16 on: Thu, 25 October 2018, 17:16:51 »
I am breaking my long tradition of lurking-only to voice my support.
« Reply #17 on: Thu, 25 October 2018, 19:26:47 »
I second USB C  :thumb:
« Reply #18 on: Thu, 25 October 2018, 19:53:07 »
10-4, me too
« Reply #19 on: Thu, 25 October 2018, 20:00:19 »
USB C to A support is fine for a keyboard.
Offline Parva Ovis
« Reply #20 on: Thu, 25 October 2018, 23:03:09 »
USB C, please.
Offline Draic
« Reply #21 on: Thu, 25 October 2018, 23:30:36 »
good idea. The left half of the split spacebar is quite short and far the the right (compared with the normal spacebars). Swapping positions with FN would definitely move it's position to a more convenient location.
Offline .
« Reply #22 on: Fri, 26 October 2018, 03:47:58 »
I put them where they are because the fn keys are closer to the thumbs, which is nice. I will also do USB-C :D
Offline RivieraS
  • Yutop
« Reply #23 on: Fri, 26 October 2018, 04:13:15 »
cant waitttttt
Offline Draic
« Reply #24 on: Fri, 26 October 2018, 06:02:52 »
Ye now having a keyboard in front of me, I agree. Position is fine, it looked just a bit off for me on the render. Still more layout options is always nice :3
« Last Edit: Fri, 26 October 2018, 06:14:55 by Draic »
Offline PaultheSloth
  • JW Double Black
« Reply #25 on: Fri, 26 October 2018, 08:37:04 »
I'm in for one, any limit on units?
Polaris|Leaf60|QXP|DC60|Planck|SKB60|Tokyo60|UT-47|AnnePro
Offline .
« Reply #26 on: Fri, 26 October 2018, 09:04:01 »
Hopefully not :)
« Reply #27 on: Fri, 26 October 2018, 09:42:30 »
Great, this will make up for the standard layout JD45 that I sold a while back & I’m glad you will be offering more than just black & silver cases!!!!
Offline RivieraS
  • Yutop
« Reply #28 on: Fri, 26 October 2018, 10:16:39 »
Hi Leader,I really want this
Offline RivieraS
  • Yutop
« Reply #29 on: Fri, 26 October 2018, 10:25:11 »
1、minila layout
2、2.25,2.75 spaces
3、left side 1.25,1.25,1.25,increase availability, fault-tolerance
4、right side 1,1,1,1.25,
« Last Edit: Fri, 26 October 2018, 10:52:54 by RivieraS »
Offline RivieraS
  • Yutop
« Reply #30 on: Fri, 26 October 2018, 10:30:56 »
And add brass weight versions please
« Reply #31 on: Fri, 26 October 2018, 10:44:09 »
1、minila layout
2、2.25,2.75 spaces
3、left side 1.25,1.25,1.25,including availability, fault-tolerance
Believe I saw some layouts that can help
@ work, so please give me an hour or two
Offline .
« Reply #32 on: Fri, 26 October 2018, 10:53:46 »
I have added it but needed to move the reset button to the left shift. Thanks for the suggestion :)
Offline .
« Reply #33 on: Fri, 26 October 2018, 10:59:42 »
I will not do that because it will make the price higher, and this board is meant to be affordable.
Offline RivieraS
  • Yutop
« Reply #34 on: Fri, 26 October 2018, 11:10:02 »
what about electrophoresis white?
Offline RivieraS
  • Yutop
« Reply #35 on: Fri, 26 October 2018, 11:24:56 »
I would like increase badge or logo design
Offline .
« Reply #36 on: Fri, 26 October 2018, 11:29:29 »
What do you mean by 'increase'?
Offline RivieraS
  • Yutop
« Reply #37 on: Fri, 26 October 2018, 11:38:51 »
I hope the keyboard have a badge or nametag ;D ;D ;D
Offline dilbertprogrammer
  • Keyboard Connoisseur
« Reply #38 on: Fri, 26 October 2018, 11:41:35 »
Looks great!  Count me in!
« Reply #39 on: Fri, 26 October 2018, 11:59:07 »
maartenwut
PM’ed you, not sure if some of what was sent can increase the price you are going for, but hope it helps
Offline .
« Reply #40 on: Fri, 26 October 2018, 12:22:03 »
maartenwut
It's unlikely it will increase the price, but I think that's a bit much of compatibility. I don't want to turn it into swiss cheese and I'm sorry I can't cover every layout.
« Reply #41 on: Fri, 26 October 2018, 12:32:48 »
maartenwut
Understood, figured it would help if had any other layout ideas.
Offline child
« Reply #42 on: Fri, 26 October 2018, 14:50:39 »
I'm strongly against the idea of putting FN in the middle. I love split space, but small key in the middle forces a very unnatural wrist movement. When I had such a layout (DZ60 with 2.25, 1.25, 2.75 split space) it was so bad the middle key was basically unused.
Offline .
« Reply #43 on: Fri, 26 October 2018, 14:55:09 »
Alright, I finished routing the PCB today. Do note that this is not final  ;)
Front
Back
« Reply #44 on: Fri, 26 October 2018, 15:15:10 »
Front
Back
Nice, I like it!
Offline .
« Reply #45 on: Fri, 26 October 2018, 15:28:44 »
Front
Back
Nice, I like it!
I'll probably slap some silkscreen art on it too, have to decide what exactly
« Reply #46 on: Fri, 26 October 2018, 16:53:35 »
Front
Back
Nice, I like it!
Great, can you provide us w/ your silkscreen ideas or do we have to wait & see?
Offline .
« Reply #47 on: Fri, 26 October 2018, 17:01:27 »
Front
Back
Nice, I like it!
I got nothing yet unfortunately. Suggestions are welcome ;)
« Reply #48 on: Fri, 26 October 2018, 17:20:18 »
What theme do you want?
« Reply #49 on: Fri, 26 October 2018, 18:19:03 »
Believe this is the best bet, an image of the available layouts on the PCB
« Last Edit: Fri, 26 October 2018, 20:29:13 by William_S_Jones »
