Author Topic: IBM made 52G9658  (Read 3424 times)
Offline ZX Spectrum
IBM made 52G9658
« on: Tue, 30 October 2018, 11:53:00 »
Hello
i would like to know about IBM modem M (52G9658):
1- beside the fact that it has permanently attached flat cable; any known issues about this keyboard?
2-how is it when in term of build-quality when compared to 1391401 units ?
3- 2-how is it when in term of build-quality when compared to Unicomp units ?
4- in general does feel cheaper than other model m units?
thanks
Offline E TwentyNine
    • Some of My Keyboards
Re: IBM made 52G9658
« Reply #1 on: Tue, 30 October 2018, 13:51:16 »
It's similar to any of the later year M's, lighter backplate, but a solid board.  Better construction than a Unicomp board.
You can get a replacement cable from Unicomp if needed.
Offline EricCartman
  • Screw you guys, I'm going home!
« Reply #2 on: Tue, 06 November 2018, 15:53:22 »
IBM modem M
It's the slow version of the Model M. Uses 56k robber domes.
« Reply #3 on: Tue, 06 November 2018, 17:17:54 »
Are you sure about that? I thought that rubber dome Ms and M2 model numbers started with "7"
I don’t give a damn. We’re making a freaking fortune, our country is getting stronger and stronger all the time.
- D Trump 2026-10-24
« Reply #4 on: Tue, 06 November 2018, 17:40:09 »
IBM modem M
Whatever you're trying to say here is wrong.   It's a buckling spring model.
Offline EricCartman
« Reply #5 on: Wed, 07 November 2018, 02:51:52 »
>modem
>56k
>robber domes
Lol you guys took that seriously....? Sheesh.
« Reply #6 on: Wed, 07 November 2018, 06:48:31 »
>modem
>56k
>robber domes
It's your third comment on this board.  Maybe contribute or go away.
