Author Topic: Black multimedia/misc keycaps (SA profile, top row) - obtainable?  (Read 4282 times)
Offline viley
    • int10h.org
This may be a long shot, but: I got this very nice set of Dolch SA double shot ABS keycaps (https://kbdfans.cn/products/maxkey-dolch-sa-double-shot-abs-keycaps). Only issue is, I'm using it on a Ducky One full-size keyboard, which has those four extra keys on the top right - Calc, Mute, Volume down, Volume up. (See layout: http://www.duckychannel.com.tw/page-en/Ducky-One-non-backlit/)
For now I'm using a few of the extra pictorial caps that came with the set, but only a couple of them fit the profile for the *top* SA row, so it's not exactly optimal.
Is there anywhere I could get some proper top-row SA caps for those functions?  Preferrably in black double-shot ABS similar to this set, and without purchasing an entire full-keyboard set of caps?
:: Web :: Blog ::
Offline seville57
Re: Black multimedia/misc keycaps (SA profile, top row) - obtainable?
« Reply #1 on: Fri, 02 November 2018, 07:38:30 »
I know what you mean, usin Ducky Shine 3 + Ducky One RGB YOTG keyboards. I have some Tai - Hao keycaps 104 sets and was joining a drop on Massdrop some years ago: Tai - Hao Hawaii set and I bought 2 sets to get 108 keys. Usin F1 - F4 from the second set.
I don't know if you have checked here: https://www.google.se/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=2ahUKEwj8yd3h2bXeAhViqIsKHcqaA9QQFjAAegQIBBAC&url=https%3A%2F%2Fpimpmykeyboard.com%2F&usg=AOvVaw0UMyQTMp_jNzmEFrFGBU69
Offline viley
    • int10h.org
« Reply #2 on: Wed, 07 November 2018, 13:36:28 »
Yep, looks like PMK do have R1 SA keycaps in black ABS - thank you.  They're blank, but I don't think I'm going to find anything with a function-specific label so that'll do fine.  (Just as well, because there'd probably be some font difference or other discrepancy that would annoy me much more than just going with blank caps.) :)
:: Web :: Blog ::
