Author Topic: Is the Microsoft Natural Ergonomic Keyboard layout actually ergonomic?  (Read 21971 times)
Offline ramencup
I've seen keyboards like these around in stores but always doubted their ergonomic benefits. The benefits of truly split keyboards come from being able to position the two halves far enough apart to alleviate strain on your shoulders, but here the two halves aren't that far apart. They're also rotated inwards, wouldn't that just put more strain on your wrists?
206547-0
EDIT: Somebody move this to Ergonomics because I just now realized that's a thing.
Offline lasttycoon
  • Ergonomic Wizard
Re: Is the Microsoft Natural Ergonomic Keyboard layout actually ergonomic?
« Reply #1 on: Thu, 01 November 2018, 13:56:46 »
As with most ergonomic questions it really comes down to the user. The Microsoft Ergo does several things right but makes a number of compromises to make the keyboard more approachable. Even if its only a little bit, separating the they keys does help for many people. Angling your hands inward like that with minimal split will help keep your wrists straight actually, although a split design with straight arms would work better for a lot of people. Another benefit that the Ergo has is that there is a negative tilt kit. These things together give a decent amount of ergonomic benefits compared to a traditional keyboard.
It's only when you compare the Ergo to the Kinesis Advantage and Ergodox that the Ergo starts to fall behind. The biggest advantage of these two keyboards are that the keys are no longer staggered, giving you a much more natural finger movement when typing.
Kinesis Advantage | Ergodox EZ Browns | RK RC930 | DS 3 Blues
« Reply #2 on: Thu, 01 November 2018, 14:02:14 »
The inner keys have been elongated, making it appear as if the halves are not as far apart as they really are.
The point with rotation is to be able to rotate your wrists so they are straight. Different people hold their wrists differently on a regular keyboard, so the MS would benefit and worsen it for different people differently.
I type on a regular keyboard with the right fingers oriented along the columns and the left hand perpendicular to the keyboard, so for me left hand might benefit a little by the rotation but the right wouldn't as my right wrist is already mostly straight. The MS "Natural" has not felt natural to me when I have used it.
Then there is tenting.. While there is a benefit from general tenting, there are three different angles for different keys — even two different angles for keys on the same column — and that is a bit weird.
Offline user 18
« Reply #3 on: Fri, 02 November 2018, 08:39:26 »
Done! :thumb:
Avatar by ashdenej
Offline RominRonin
« Reply #4 on: Fri, 02 November 2018, 15:31:05 »
Some great points made so far. I'd like to add some observations.
The palm rest on the MSNEK4000 is the most comfortable palm rest I've used on any keyboard. There is a soft, springy sponge pasted atop the moulded plastic rest, and that is covered with a soft faux leather (velour?) sheet. The combination of the materials and the shape/height/angle is exceptionally well designed.
There are those who say that resting your palms while typing is bad for you. Indeed those who attended touch typing courses know that hovering your hands and fingers above the keys is considered good technique. But this keyboard proves that it can be comfortable to touch-type while resting your palms.
One of my biggest gripes with legacy keyboard layouts (that's 'normal' layouts to most people) is the asymmetric reverse-stagger. If you're touch typing, the left hand adopts a twist towards the left that can cause aches and pains when typing for longer periods.
The MSNEK4000 actually reshapes the keys on the left hand side to compensate for this funky reverse-stagger, look at how wide the tab key is, this encourages a tilt to a better natural position for the left hand*:
This keyboard is aimed at working touch-typists and is designed to allow them to work in comfort - certainly with more comfort than a regular office keyboard.
So quickly referring to Dictionary.app on MacOS:
"Ergonomic: relating to or designed for efficiency and comfort in the working environment"
While I think the efficiency of any given keyboard shape, layout, switch etc. is immeasurable, I think this keyboard is certainly designed for comfort. By that definition, it undeniably IS ergonomic.
* Incidentally, I don't think MS went far enough with this correction of the left hand stagger, this is one of the reasons I started investigating the Katana layout.
« Last Edit: Fri, 02 November 2018, 15:32:58 by RominRonin »
Offline vvp
« Reply #5 on: Fri, 02 November 2018, 15:57:48 »
You should not use it if your wrists are not straight when your palms rest on it. The palm rest is too low to be useful.
I used an ergonomic keyboard like this one (different producer but similar shape). A switch to Kinesis advantage was a very good move. A later switch to my custom built Katy was even better :)
Offline RominRonin
« Reply #6 on: Sat, 03 November 2018, 04:16:25 »
Indeed. When I was using it, I attached the plastic riser - bundled with the keyboard:
I saw the build logs of the Katy, I'm a fan ;)
I tried a variety of ergonomic and split boards: Dactyl, ErgoDox, Atreus62, Planck. I still find myself caressing the MSNEK because it is SO comfortable - those other boards don't compare as far as comfort goes.
As for typing comfort, I still find that hovering your hands is the most comfortable approach.
The Katy and the Dactyl are exceptions, since those boards are designed to be used with your palms rested flat.
BTW, did you ever consider doing a group-buy for the KATY?
Offline vvp
« Reply #7 on: Sun, 04 November 2018, 03:35:29 »
I'll do it if I find a way how to make it cheaper. There is about 37 hours of manual work building it now. That is too much and it would make it too expensive. It is only for people who enjoy building it themselves for now.
Offline BundleOfJoysticks
« Reply #8 on: Sun, 20 January 2019, 00:30:26 »
I'll never be able not to call it the em-snek now.
Offline Squarism
« Reply #9 on: Sun, 20 January 2019, 06:54:32 »
Ive been usling natural keyb 4k for the last 10 years. I say tis Good, but could be getter. The wrist wrest isn't tented enough for me and lately I've developed pain where the bone meets it. Thumbs not used tp fullm potential. So, not the final solution but the best budget alternative maybe.
UPDATE: I actually worn away the fake leather the wrist rest, NK4k has, on one point at left of the keyboard. Just in the last couple of days ive used a new keyboard wo the wrist rest. I now support my arms on my armchair rests only. I should have been clear this was a problem cause i have had more pain on my left hand at the point where it rests on the NK4k. So, to me it appears the wrist rest actually has been harmful.
« Last Edit: Wed, 23 January 2019, 12:35:02 by Squarism »
Offline macroxue
    • Darknight: DIY 60% Split Keyboard
« Reply #10 on: Wed, 23 January 2019, 22:00:02 »
I used MS Natural 4000 for half a year at work and eventually threw it away. My main complaint was about the sticky space bar. I literally had to hammer on it. Save your thumbs unless you can find one with a good space bar.
[Darknight: DIY 60% Split Keyboard](https://github.com/macroxue/keyboard-diy)
Offline RominRonin
« Reply #11 on: Thu, 31 January 2019, 14:14:38 »
This really made me laugh!
Lol, I've started calling it that now!
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #12 on: Thu, 31 January 2019, 17:25:34 »
MSNEK tis a creaky snek iirc. Much clonk, less yoink, sometimes yeet.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #13 on: Fri, 01 March 2019, 08:11:02 »
By default my hands and some other peoples hands go inward, so i think that's why microsoft incorporated it into their design.
Fun fact: This keyboard was featured in The Matrix
Just my thoughts
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #14 on: Fri, 01 March 2019, 10:07:48 »
If we're going by keyboards featured in modern films I'd say the Kinesis Advantage in the first Men In Black movie beats any ole MSNEK.
I'm just salty because my Ergo 4000 black/grey keyboard had this creaky plasticy sound (back/forward buttons especially) and the scrolling thing was very mushy.  iirc it was the first keyboard I bought new after using plenty of hand-me-down buckling spring boards.
I'd image a modern youtuber might get a kick out of wrenching one of those MS Ergo boards.  So creaky if memory serves me.
Offline mkkeyboardvigilante
  • Location: Atlanta, GA, thocking, clicking, and clacking away depending on my mood
« Reply #15 on: Sun, 10 March 2019, 17:47:40 »
Yuck, not for me. That spacebar on the one I had felt like pounding an iron brick, and I typed at least 30 WPM slower every time I tried to give that keyboard another shot, and this is coming from someone who already knows how to touch type without looking at any of the keys. I don't know how my programmer boss is able to cope with typing on it. She has carpal tunnel syndrome and that's the main reason she types on it all the time. She even told me the older version of that keyboard was much better, but much harder to find at a reasonable price online and on Ebay. I gave her the one I used at work since the one she was using broke and all.
I also never liked how huge and bulky this keyboard looked at all. I prefer my boards to be on the smaller side. :)
It's hidden away deep in my walk-in closet now, never to be used again.
It's cousin the Microsoft Comfort Curve 5050 was a bit better though, but after at least an hour or two of typing on it, my hands were already tingly and in pain from that one too. Still want to either sell these boards or give em away at Goodwill or something. I have also heard of another version of this KB called the Microsoft Surface Ergonomic Keyboard, but that one I think uses chiclet keys. Never used it before.
« Last Edit: Sun, 10 March 2019, 17:55:47 by mkkeyboardvigilante »
Current driver: HHKB Pro 2 (BKE Ultra Lights), Wooting One w/ Flaretech Red switches and HyperX PBT keycaps.
Other keyboards I own and like: Realforce 87U Variable Weight, Realforce 87U 55g, Niz Plum, Magicforce 108 Gateron Reds w/ O-Rings.
Other keyboards I have: Magicforce 68 Cherry MX Brown, Havit Low-Profile Kailh Blue, Logitech K740,
Yeah, it's a loooooooooooot of keyboards. :P
Offline RSanders
  • DataHand Pro II > Maltron > Kinesis > Flat Boards
    • LinkedIn Profile
« Reply #16 on: Fri, 13 September 2019, 10:07:12 »
When I worked as a medical transcriptionist many years ago and before I had a clue what an ergonomic keyboard really should be, I had the immense displeasure of using one of those. The key pressure was excessive and the overall layout came across as a half-hearted attempt to be just ergonomic enough to be called ergonomic. The old white/cream-colored ones also had problems with the key legends rubbing off from use but for touch typists this is a minor quibble at best. I actually preferred typing on the IBM Model M, which I still keep in rotation to this day.  In my opinion, the Microsoft Natural is very, very marginally better than a regular flat keyboard only because of the very slight rotation of the left and right sets of keys allowing the wrists to not have to rotate clockwise/anti-clockwise and the very slight tenting at the center. The excessive key force, at least on the original versions, effectively negated any real benefit. The current model just looks like it has been cosmetically updated. I did briefly type on a colleagues when I was doing some software installations and It felt like the key pressure is still just as bad.   I always shudder when I see or hear of a coworker being recommended one from supposed ergonomics experts during routine desktop ergonomics evaluations.  Some people really like them but, I suspect this is from a lack of having been exposed to truly ergonomic keyboard options.
