Author Topic: DIY TRRS Jack  (Read 3857 times)
Offline SectorOMEGA
DIY TRRS Jack
« on: Fri, 02 November 2018, 04:29:37 »
I have just completed a quefrency build and looking for a custom TRRS cable. Is there anything I have to follow or specific alignment of the cables?
Thank you in advance :)
Re: DIY TRRS Jack
« Reply #1 on: Sun, 04 November 2018, 09:51:36 »
Wire is wire - just make sure you connect each wires to the same contact on both connectors and it will work.
Also please note that TRRS connectors will short so this cable should only be plugged in or unplugged while the keyboard isn't powered on or you might damage the controller chip.
Offline SectorOMEGA
Re: DIY TRRS Jack
« Reply #2 on: Tue, 06 November 2018, 03:14:03 »
Ahh nice one :) Didnt know about the shortage so I learned something new :)
