Author Topic: PS/2 Keyboard Recommendations  (Read 2651 times)
Offline Smack2k
« on: Sat, 03 November 2018, 11:39:11 »
Hey all,
New here and not very knowledgable of individual switches / types / etc so forgive my ignorance
I am looking to possibly replace my two IBM PS/2 Keyboards (KB-7953 and KB-9910) with two mechanical PS/2 Keyboards for my retro PC setups.
Looking for some recommendations on what to look for, possibly buy to replace them.  I love the sound and feel of the mechanical keyboards like the Model Ms I used to have, but dont know what to look for / what's good, bad, etc...
Appreciate any assistance I can get
Offline Tactile
Re: PS/2 Keyboard Recommendations
« Reply #1 on: Sat, 03 November 2018, 13:18:57 »
Unicomp still make the Model M. The old style, or black if you want. Or they also have a smaller size which includes Windows keys in white or black.
Lots of folks here will tell you to find an old one 'cause the quality is better. I've owned a couple of Unicomp boards and they're fine keyboards. Thinner plastic than one from 1982, yes but, unless you're a collector, who cares? These are fine keyboards and well worth the price.
REΛLFORCE
Offline Smack2k
« Reply #2 on: Sun, 04 November 2018, 09:07:35 »
Thanks, I will look into those..
« Reply #3 on: Sun, 04 November 2018, 10:01:38 »
Dell AT101 is good, especially if you want to get into modding the switches, and is available in either beige or black, if you need black.
I don’t give a damn. We’re making a freaking fortune, our country is getting stronger and stronger all the time.
- D Trump 2026-10-24
Offline Smack2k
« Reply #4 on: Sun, 04 November 2018, 17:24:51 »
I have a Dell AT101W that is pretty dirty.....could take it apart and clean it up for one of the two keyboards....
I also have the following in my bin, not sure if any would suffice as decent
Epson T026A
NMB RT101+
NMB RT6855TW (x2)
Fujitsu FKB4700
Any worth cleaning up fully and using?
Looked on Unicomp...I may be getting one of those for my main rig...
« Reply #5 on: Sun, 04 November 2018, 19:53:50 »
I love NMB Hi-Tek "Space Invaders" particularly the clicky black ones. Unfortunately they are difficult to take apart, just do a minimal cleaning if you can.
Offline Smack2k
« Reply #6 on: Sun, 04 November 2018, 20:22:26 »
 Thanks for the tip, that was gonna be the next thing I did was try and take one of those apart....I will clean it as best I can...
