Author Topic: Enter key for CM Storm QFR?  (Read 4603 times)
Offline macguy80
« on: Mon, 05 November 2018, 02:15:44 »
I have a 97-year-old friend. Whenever I ask her to find the Enter key, she can't, because it doesn't literally say Enter. Is there any place you know of that I can buy JUST a standard ANSI key labeled "Enter", instead of an icon? A whole keyset would be too much.
Re: Enter key for CM Storm QFR?
« Reply #1 on: Mon, 05 November 2018, 06:06:36 »
https://elitekeyboards.com/products.php?sub=access,cherrymxkeys&pid=dmx_enter_red_tw
I assume these guys are still in business.
« Reply #2 on: Tue, 06 November 2018, 19:44:04 »
Having a different colour key is also a good idea - it would stand out more.  "Press the red key", for example.
Offline macguy80
« Reply #3 on: Tue, 13 November 2018, 23:35:41 »
One could easily be forgiven for wondering that, based on the apparent fact that only ONE model of keyboard is presently listed as being in stock. Can someone tell me what kind of stabs the QFR has, and any tips, if it happens to be Costar?
With regard to the keycap linked above, is it going to matter? If so, it doesn't say which type it's made for.
Offline macguy80
« Reply #4 on: Tue, 13 November 2018, 23:37:59 »
Yes!
« Reply #5 on: Wed, 14 November 2018, 19:48:12 »
QFR = Costar.
The keycap SpAmRaY linked to looks like one from their similarly-coloured sets.  I have a green set 9thanks SpAmRaY!) - they are thin ABS with tampo printing.  I ahve not used it enough to wear the legends off, but they probably would wear after a short period of use.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #6 on: Sat, 17 November 2018, 07:56:28 »
http://www.wasdkeyboards.com/index.php/products/printed-keycap-singles.html
Though generally considering the shipping cost and stuff it's not very cost effective to buy just one key but otherwise this will be a good fit.
