Author Topic: Mechanical switch that allows 'hovering'?  (Read 3542 times)
Offline SpatiallyAware
« on: Wed, 05 May 2010, 09:09:44 »
I've found that the cherry blue doesn't work well with the type of FPS gaming I do.  It's fantastic for typing, but double tapping is difficult and I can't 'hover' near the actuation point.  Also once I pass the actuation point I have to completely release the key before I press it again which slows me down.
Will a linear switch help with this?  I really like the Deck keyboards but I'd like to be fairly confident that one of their switches will work with my gaming style..
Thoughts?
Offline kriminal
« Reply #1 on: Wed, 05 May 2010, 09:24:17 »
Quote from: ripster;179137
A gaming pro wandered through here once and said Cherry Blacks FTW.
Although a pro could probably win using a rubber dome and a $10 mouse that was good enough for me.
lmao... true
cherry blacks win for gaming...
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
« Reply #2 on: Wed, 05 May 2010, 12:47:12 »
Hmm...  Alright, I think I'm going to go for the Deck with the linear black switches..
Does anyone have a quick link to the chart that shows actuation and tactile points for Cherry switches?
« Reply #3 on: Wed, 05 May 2010, 13:01:33 »
Thanks Ripster, this actually has a clearer version:
http://www.overclock.net/computer-peripherals/491752-mechanical-keyboard-guide.html
http://www.overclock.net/picture.php?albumid=2267&pictureid=12840
Based on the graph of the blacks I think they'll work for hovering, since the actuation and release is in the same place versus the blues/browns where you have to almost completely release the key before pressing it again..
Offline Nonmouse
« Reply #4 on: Wed, 05 May 2010, 13:33:45 »
Quote from: SpatiallyAware;179213
You also might consider swapping out the springs to get pseudo-red switches- linear, but with lower force.  (Boards with real reds are nearly impossible to find, at least in the States.)
« Reply #5 on: Wed, 05 May 2010, 13:42:27 »
Quote from: Nonmouse;179242
How difficult is it to swap springs in a deck?  It appears as though the switch would need desoldered from the board..
Offline Nonmouse
« Reply #6 on: Wed, 05 May 2010, 14:27:35 »
Quote from: SpatiallyAware;179244
If they're PCB-mounted, it's a piece of cake.  If they're plate-mounted, you have to desolder them.  I don't recall which way the Deck keys are mounted- but I'm sure somebody around here does...
Edit: After a quick search, it looks like the Deck is PCB mount.  Easy-peasy.
« Last Edit: Wed, 05 May 2010, 14:30:44 by Nonmouse »
Offline elbowglue
« Reply #7 on: Wed, 05 May 2010, 14:55:39 »
No no no- the deck is very difficult to mod.  Here is why - they all have LED's in them, the LED's do not allow you to pop off the cap of the switch housing because they will get in the way.
To replace any switches you need to desolder the switch and the LED as well.  Thus the Deck is a PITA to swap switches in.
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline ricercar
  • mostly abides
« Reply #8 on: Wed, 05 May 2010, 18:18:07 »
Quote from: SpatiallyAware;179220
Buy my TG3. It's got Cherry blacks, and is made by the OEM that supplies Deck with their keyboards.
Offline Nonmouse
« Reply #9 on: Wed, 05 May 2010, 19:20:17 »
Meh, Just cut off the stupid LEDs.
I had misinterpreted it and thought the Deck didn't have the LEDs and the TG-whatever did.  Shoulda read instead of skimmed.
Still, de-soldering and re-soldering the LEDs shouldn't be that big a job, unless there's something in the way on the underside of the PCB...
« Reply #10 on: Wed, 05 May 2010, 20:03:02 »
Nah I'm not worried about it, I'll probably do the arrows just to see how it feels, then possibly WASD.
And no thanks on the TG3, I'm looking for a full size.  Also, it seems like I read somewhere that there's a splash guard that drastically affects the way the keys feel?
I'm really leaning towards the black toxic deck, I wish I could see these in person though..  Any tips?
Thanks all!
Offline ricercar
  • mostly abides
« Reply #11 on: Wed, 05 May 2010, 22:37:23 »
There are two kinds of splash guard: rubber and saran wrap. Both flavors of splash guard are removable.
The TG3 rubber splash guards affect the key feel, I haven't measured it but imagine it's more like 85 or 90 grams. The saran wrap splash guard doesn't change the way a Cherry black feels.
« Last Edit: Wed, 05 May 2010, 22:39:57 by ricercar »
