Author Topic: [IC]Typewriter68 custom retro keyboard  (Read 42223 times)
Offline mrpetrov
Re: [IC]Typewriter68 custom retro keyboard
« Reply #50 on: Thu, 15 November 2018, 00:11:07 »
Do you have a better picture of what the green looks like?  Also, can we have some more details on the PCB - is it 3- or 5- pin and (presumably) it is *not* hotswap?
EDIT: I'm confused - can you get the whole keyboard in green or only the "mid-piece" (whatever that is??)?
Thanks.
Because Chinese people don't have green players in the whole shell, so there is no physical picture of the whole shell.
and there is pcb sample:
Thanks for the response. Are you saying you cannot get the whole shell in green - is that correct?
Offline ZyBeR
« Reply #51 on: Thu, 15 November 2018, 02:25:17 »
I just noticed that a Group Buy for the Typewriter68 came up on zF now, cool!
I have some questions though.
1. How thick is the plate and how thick can it be made? This keeb seam super solid so I'm hoping the plate to be massive.
2. The colors shown was (to me) kind of "meeh", I think this design deserves gold and and more extravagant colors.
(personally I would love to see a green color option)
Here are the colors:
the plate is 1.6mm thick and the middle frame is 9.6mm thick.
Thank you for replying.
1.6mm is disappointing for a keyboard at this level. Look at the Doro67 it has a 4mm plate, the Zeal60 has a 5mm. A tick plate gives a ridgid, high end feeling which a thin one can't compare with.
I hope you can consider a ticker plate, preferably as tick as the Zeal as everything else in your design is top level.
oh!the plate and the middle frame are integrated,so when you actually get it,is a whole,quite thick.
Check this out, all these high-end keyboards have at least a 4mm plate.
I'm sorry to say, but a 1.6mm makes this awesome project less interesting for me. Would it have a solid 4 or 5mm plate I would be all over it :)
Doro67 4mm integrated plate
Rama Koyo 4.5mm integrated plate
Zeal Zephyr 5mm brass plate
Offline Scarecrow
« Reply #52 on: Thu, 15 November 2018, 08:01:58 »
Thanks.
no,i mean no one in China is doing all green.If you want, we can do it for you.
Offline toby
« Reply #53 on: Thu, 15 November 2018, 08:42:09 »
very fresh design, i am interested!
Offline Scarecrow
« Reply #54 on: Thu, 15 November 2018, 09:32:21 »
THX!
Offline elmo
  • Hello I like keyboards
    • Elmo's keyboards
« Reply #55 on: Thu, 15 November 2018, 10:11:58 »
Sooooo...
The groupbuy is already live on zfrontier without a thread here or any word about it?
https://en.zfrontier.com/collections/keyboards/products/tw68
Offline vonswoopington
« Reply #56 on: Thu, 15 November 2018, 11:08:30 »
i am tempted to give up my CA66 spot and get this instead.
This is a confusing gb so here are my questions:
-What is the mid-piece? Is that the integrated plate?
-I see that there is a green housing option now. Any samples?
-Where do input our own text for brass engraving?
-Non-engraved means it won't have that long sentence on the top of the case?  If we choose "engraved" does that mean we can put in our own text?  If so, where do we input that?
TGR 910 Polycarb | TGR Alice | TGR Unikorn | Lyn EM-7 | VE.A | Kyuu | E7-V1
Offline elmo
    • Elmo's keyboards
« Reply #57 on: Thu, 15 November 2018, 13:03:56 »
Are there by any chance more pictures or renders with other color combinations?
Only seeing the silver/black (i guess?) variant is a bit scant...
Offline KaosJ
« Reply #58 on: Thu, 15 November 2018, 16:22:28 »
After 3 days of GB, these links still aren't working...
Also still isn't clear:
- which is the part that we can decide to NOT engrave, which one of the two? The "Typewriter" or the long disney random text?
- Did typewriter changed font yes or no?
- So can the keyboard support 1.25x3+6.25 standard bottom row on the non-hhkb version, yes or no? (from your last reply seems like no, but to be sure i just ask it again, can you make it compatible with the standard bottom-row on the non-hhkb layout?)
« Last Edit: Thu, 15 November 2018, 16:29:33 by KaosJ »
Offline Scarecrow
« Reply #59 on: Thu, 15 November 2018, 21:08:15 »
1.two part can decide to NOT engrave,include "Typewriter" and text.
2.yes.You can show the font you want in the post.
3.no,incompatible.
by the way,GB page problem i have contacted zfrontier,they will make changes soon. Thanks!
Offline p_blaze
« Reply #60 on: Thu, 15 November 2018, 21:13:40 »
Honestly, I'd be down if there was an option for a plate with F-row
Offline Scarecrow
« Reply #61 on: Thu, 15 November 2018, 21:45:37 »
1.there is integrated plate.
2.because no one in China choose all green,so I only have “part” green sample.
3.you can find this on the GB page.
4.the long sentence carved only on the side of the case,you can put in our own text,also input by email.
« Reply #62 on: Fri, 16 November 2018, 00:48:32 »
[ Specified attachment is not available ] [ Specified attachment is not available ]
Thanks for the response.  Also, the link to the vector file isn't working.
I put together and image with the options.  Is it correct?
« Last Edit: Fri, 16 November 2018, 00:52:59 by vonswoopington »
Offline elmo
    • Elmo's keyboards
« Reply #63 on: Fri, 16 November 2018, 02:37:16 »
Would it be possible to add an additional PCB in the extra parts?
It's always nice to have a spare in case the first one breaks or so...
Offline ZyBeR
« Reply #64 on: Fri, 16 November 2018, 07:52:29 »
I'm very interested but there are still questions unanswered and it would be nice with more pictures.
Have you considered the plate thickness?
Offline Scarecrow
« Reply #65 on: Fri, 16 November 2018, 23:43:01 »
Link problem I will contact ZF immediately.
you are right.
Offline Scarecrow
« Reply #66 on: Sat, 17 November 2018, 04:29:18 »
I want to explain here about the thickness of the plate:
This keyboard is a integrated middle frame and plate.Well known,the material and casing of the plate are different,but I use the same material.It is equivalent to doing this integrated plate with the standard of the casing,so its reliability can be guaranteed.We are willing to use so much material to make such a retro shell,without thickening the plate,because I think thick plates can affect the feel.Don't influence your opinion because of the appearance of several thick plate products.Thick plates do not necessarily bring a better feel.I don't want to see the vibration feedback of the switch affected by the thickness of the plate.
Offline japanesehorrorwriter
« Reply #67 on: Sat, 17 November 2018, 19:21:16 »
Nice. After understanding this I will be jumping in too. Thanks for the clarity.
Offline Scarecrow
« Reply #68 on: Sun, 18 November 2018, 09:10:18 »
thanks!
Offline elmo
    • Elmo's keyboards
« Reply #69 on: Mon, 19 November 2018, 02:37:10 »
So no additional PCB possible and no pictures/renders with different color combinations?
« Reply #70 on: Mon, 19 November 2018, 13:07:44 »
You could order additional pcbs here: https://en.zfrontier.com/products/tw68-custom
Offline elmo
    • Elmo's keyboards
« Reply #71 on: Mon, 19 November 2018, 13:10:47 »
I don't see any option for an additional PCB there...
It's also not possible to select additional colored aluminium nametags
« Last Edit: Mon, 19 November 2018, 13:14:09 by elmo »
« Reply #72 on: Mon, 19 November 2018, 13:31:34 »
You're right. Will let the OP answer. Thought it would be under extra options....
Offline Scarecrow
« Reply #73 on: Tue, 20 November 2018, 08:50:36 »
i will contact ZF.
sorry to have so many problems.
Offline venderzhao
« Reply #74 on: Tue, 20 November 2018, 18:12:46 »
i will contact ZF.
I told zF to add this too! they will soon!
Offline ZyBeR
« Reply #75 on: Wed, 21 November 2018, 01:09:55 »
Can we have more pictures?
How many test units have you manufactured?
Have you made any similar things before or is this your first time manufacturing and running a group buy?
Offline elmo
    • Elmo's keyboards
« Reply #76 on: Wed, 21 November 2018, 10:43:35 »
Extra parts are available now.
Thanks for the help  :D
Going to place my order on payday because I'm totally broke right now :'D
Offline Morgan3Wheeler
« Reply #77 on: Wed, 21 November 2018, 23:57:31 »
I want to see green color sample(small Aliminium plate)
KMAC Happy red HHKB / KMAC Mini red / KMAC 2 86 / 45-ATS cerakote white / Matrix Noah avocado green / Matrix2.0 WKL yellow / Matrix2.0 WKL red / Matrix2.0 add WKL / Matrix Abel X RX-78 / Matrix Abel X Eva / Matrix1.2 OG WKL purple blue / Percent BOOSTER yellow /  Percent CANOE yellow / Percent Canoe2 casio / Percent SKOG mao / TGR 910 CE pink / TGR Jane CE WKL olive green/ TGR Jane V2 WKL blue gray/ TGR Jane V2 CE WKL / TGR Alice red / Keycult No. 2 Rev. 1 / EXENT65 black / GRAYCOD 67 mao / CA66 e-white / Think6.5 V2 LE / Think6.5 V2 robocop / Think6.5 V2 snow white / SPACE 65 R1 black / Typewriter68 e-white/ E6.5 pc / E7-V1 mao white/ E8.5 WKL e-white/ Voclano660 e-white / Moon by EVE WKL carbon / JER-Mini gray / JER80S NCR WKL geekhack / JER80S NCR WKL Korean / Dolumina65 black / Elephant S7 R2 e-white / Bear 65 ergo e-white, black, blue, pink, PC / Fox key65 e-white / Cyberboard purple / Saturn-60 moondust / Saturn-60 supernova / Infinitum / Rama M65a e-white / Rama Jules navy / Rama Zenith ouro / Rama U80-A Seq2 soya / Primus75 / 7V blue / / Cajal gray / Cajal e-white / SQUARE.X 6ea / Time 80 Reforged WKL e-white / J-01 rev1 Black / J-02 LE Poker e-white / OTD 356 Mini R1 red / LZ-CE red / LZ-CE gray / LZ-CLSms silver/ LZ-PhysiX gray / LZ-SQ SE titan gray / LZ-EX titan gray /  LZ-ST silver / LZ-FE WKL silver/ LZ-CLS WKL silver/ LZ-CLS WKL black / LZ-MP gray / LZ-MX SE titan gray / LZ-CP black-blue / LZ-CP red-red SE / LZ-RV gray / Light Pad silver / Light Pad gray / Octagon V2 gray / Orion V2 WKL silver-red / Orion V2.5 WKL gray / Dol Pad dolch / Dolinger 2017 dolch / Dolinger RE yellow/ Dolinger RE PC / Whale-Fe / Dolphin V3 dolch / Montage PC WKL / F1-8X WKL gray / F1-8X WKL navy / F1-8X WKL burgandy / AL.BOK WKL silver
Offline Scarecrow
« Reply #78 on: Thu, 22 November 2018, 07:59:29 »
Because I only made one sample,so no more color matching.
This is my first time running a group buy,and this keyboard will manufactured by ALF,he is my friend :D
Offline Scarecrow
« Reply #79 on: Thu, 22 November 2018, 10:08:08 »
Offline ZyBeR
« Reply #80 on: Thu, 22 November 2018, 10:40:46 »
Ahh, wasn't ALF involved with the Doro67?
Offline elmo
    • Elmo's keyboards
« Reply #81 on: Thu, 22 November 2018, 10:48:27 »
Oh boy. Those X3 Renova's in the background.
I want one...  :-X
Offline mrpetrov
« Reply #82 on: Thu, 22 November 2018, 11:56:01 »
Yes, he/they are making the Doro67 if/when it arrives.
Offline tearai
« Reply #83 on: Thu, 22 November 2018, 21:00:35 »
Hi scarecrow, is it possible for zfrontier to split out the custom engraving on the housing into 2 options? I would like the 'typewriter' logo to be engraved but not the sentence along the front. should we email to let them know about this?
« Reply #84 on: Fri, 23 November 2018, 01:43:45 »
Me too!!!
Offline Scarecrow
« Reply #85 on: Fri, 23 November 2018, 04:21:14 »
yeah,you can contact by email.
when GB end,i will give you some 'typewriter' logo font options to choose from.
Offline Scarecrow
« Reply #86 on: Mon, 26 November 2018, 08:32:18 »
I want one...  :-X
yeah,they are about to ship :D
« Reply #87 on: Fri, 07 December 2018, 06:03:38 »
I am in....When will you send typewriter logo?
Offline elmo
    • Elmo's keyboards
« Reply #88 on: Mon, 14 January 2019, 11:14:23 »
Any updates on the production status?
Buying phase is over for a while now and we haven't heard or seen anything for a while now.  :rolleyes:
