Advanced search
it just clicks
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Projects
Making Stuff Together!
(Moderator:
Soarer
Easiest method for soldering a bunch of SMT devices? (diodes, caps, resistors)
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Easiest method for soldering a bunch of SMT devices? (diodes, caps, resistors) (Read 4215 times)
Croktopus
Thread Starter
on:
Fri, 09 November 2018, 02:31:03 »
Was wondering what peoples' favorite techniques are. About to put together a custom board, and I've never used SMDs before. I was planning on the "tack and reflow" method shown off in this eevblog video
, but I was wondering if people generally prefer to use solder paste and a hot air rework station or some other method? The board's gonna have around 150 of these small SMDs, so I kinda wanna streamline the process (especially since I'm making a few of them). fwiw almost all the devices are 0805
Thanks for any advice
Last Edit: Fri, 09 November 2018, 02:35:06 by Croktopus
Logged
kakan
Re: Easiest method for soldering a bunch of SMT devices? (diodes, caps, resistors)
Reply #1 on:
Fri, 09 November 2018, 10:42:40 »
If you like tinkering and mastering a production technique I would go with a hot oven.
If you are looking to do it cheaply just use your iron.
I like to test the methods I can afford. As equipment gets expensive. But I do it because I enjoy soldering and it has been a hobby of mine for a long time.
Logged
Croktopus
Thread Starter
Reply #2 on:
Mon, 12 November 2018, 06:54:19 »
Alright, think I'll just do the tacking thing for now, and if i end up doing more than like, 2 or 3, ill look into the oven thing
thanks dude
Logged
cy384
Reply #3 on:
Mon, 12 November 2018, 11:00:29 »
toaster oven or hotplate, and get a cheap solder stencil from
https://www.oshstencils.com/
or somewhere, hand-soldering is way too finicky and tedious for me.
Logged
_rubik
Esteemed Elder
Typing on: Brutal60, Lavenders Linears, GMK Jamon
Reply #4 on:
Mon, 12 November 2018, 11:03:36 »
I'm a big fan of a hot air station, but those can get pricey. Depending on your iron and tips, that could work
If the components your working with are cheap, give it a try with your iron. Otherwise, the investment might be worth while.
Logged
ai03 Meridian
Mech 27
E8.5
Brutal60
SSK White Label
HHKB Pro JP
vAEK68 Alps Blues
RF87u
Signature
master of puppers
Marketplace Moderator
snoozing
Reply #5 on:
Mon, 12 November 2018, 11:05:27 »
hot oven or hot air is the way to go if you have 150+ stuff to solder. You can ofc do it with soldering iron but it's really tedious. If you go with iron method, I'd recommend getting a "helping hand" or a pair of reading glasses, aswell as a really fine tip for the soldering iron.
WFD has a good vid on hot air:
Logged
Croktopus
Thread Starter
Reply #6 on:
Wed, 14 November 2018, 01:57:26 »
Thanks for all the advice! I think I'll go the hot air route cuz that video makes it look nice - was worried about air pressure blowing it away but i guess it should be alright at low pressure. definitely check out the stencil for my next project, as much for possible ease of use as for experience with the technique
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Projects
(Moderator:
Soarer
