Author Topic: Blackest of Black PBT  (Read 4611 times)
Offline Naack
« on: Tue, 13 November 2018, 02:31:20 »
Geetings!
I was wondering if any of you have any leads as to where someone could get pitch black blank PBT keycaps (Cherry Profile).
I have a set of enjoyPBT that I bought off of KBDfans, and they are wonderful caps, but the darkest they come is a deep grey.
Cheers!
Offline nmur
  • ಠ_ಠ
Re: Blackest of Black PBT
« Reply #1 on: Tue, 13 November 2018, 03:25:32 »
I'm not aware of any (readily available) PBT sets that are darker than that
ABS sets are much darker
There are also PPS caps
https://www.reddit.com/r/MechanicalKeyboards/comments/75ov9b/pps_keycap_review/
however these would be hard to find
Offline intelli78
« Reply #2 on: Tue, 13 November 2018, 04:32:06 »
I have some black DCS blanks that are significantly darker than ePBT, if that helps. Not sure about cherry profile. Leopold PBT caps are extremely similar to Cherry and I remember them being pretty black, but I don't have them on hand to compare.
P.S., the sound of those PPS caps are making my PP very not S.
« Reply #3 on: Tue, 13 November 2018, 10:44:41 »
PPS is definitely a darker color than the PBT, but ABS caps will be darker than either one.
Offline Naack
« Reply #4 on: Tue, 13 November 2018, 12:01:07 »
With that in mind, does anyone have a link to good black blank Cherry style key caps? I did some searching around on Google and found a fair amount, but just wanted to know what everyone's favourite is.
Offline Tactile
« Reply #5 on: Tue, 13 November 2018, 17:36:07 »
Have you considered dyeing the dark grey caps to black? Dyeing to a specific shade of blue or something might be tough but I'd think just plain black should be a pretty easy process.
REΛLFORCE
