Author Topic: What do you recommend for numberpads? Ones that send actual numberpad codes  (Read 63673 times)
Offline NorrisB
What are some good ones?
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Moderator
  • The 00verseer of Vault 77
    • Mechanical Keyboards
Re: What do you recommend for numberpads? Ones that send actual numberpad codes
« Reply #1 on: Tue, 20 November 2018, 21:08:52 »
Leopold makes a really good one.
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
