Author Topic: g80/81-1800 dip switch to at or pc  (Read 2717 times)
Offline Tr0j4nM4x1mus
« on: Thu, 06 May 2010, 00:13:44 »
I acquired a that keyboard & it has the big at plug (have an adapter on the way) it has a dip switch on back the can be set to at or pc...which do I set it to??
thank you
Keyboards - 4 Cherry G80-3000lscrc-2 (two with black DS keys one with black & white DS keys)
HHKB Professional white
2 ABS M1 (modded with complicated alps one with pinks & one with rubber bumper whites)
2 IBM Model M\'s one 89 & one 97
Dell AT-101W black (modded with rubber bumper whites- M1 keys)
Focus FK2001 with cover
Focus FK2000 with cover
Unicomp Model M black mighty mouse
Cherry G84-4100 white
Looking For - Compaq G80-1838
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #1 on: Thu, 06 May 2010, 00:16:53 »
AT.
The IBM PC lineup started with the PC (5150 and variants if any), then the PC/XT (5160 and variants), then the PC/AT (5170 and variants).
The PC and PC/XT used one particular keyboard interface, a 5-pin DIN plug with a particular pinout and particular protocol. The PC/AT introduced a new interface using the same physical plug and same pinout, but with changes to the protocol that prevent the keyboards being interchangeable unless they're the switchable type or autosensing.
PS/2 uses the same protocol AT did, so a simple adapter with no conversion circuitry allows AT keyboards to work on PS/2 ports and vice versa.
« Last Edit: Thu, 06 May 2010, 00:19:36 by kishy »
kishy.ca
« Reply #2 on: Thu, 06 May 2010, 00:17:51 »
thank you
« Last Edit: Thu, 06 May 2010, 00:22:03 by Tr0j4nM4x1mus »
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #3 on: Thu, 06 May 2010, 00:20:04 »
Quote from: Tr0j4nM4x1mus;179428
thank you...what is the pc there for??
Refer to my edit, lol. Figured I could do it quick enough, apparently not.
kishy.ca
Offline elbowglue
« Reply #4 on: Thu, 06 May 2010, 00:34:57 »
I hope you got the g80-1800 not the g81-1800. :)
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
« Reply #5 on: Thu, 06 May 2010, 00:49:03 »
no ..... I wasn't so lucky...it's older but it still has the my switches...it does however have a really nice set of black double shots & has the regular enter key ...it's a nice board besides the my switches
