Author Topic: Where to buy parts to make custom usb cables  (Read 5107 times)
Offline bloggerstomper
« on: Fri, 16 November 2018, 12:49:38 »
Hi all! As the title says, I want to get into custom USB cable making and I'm trying to research places where one can buy parts.
So far my search has turned very little results, as many listings on Aliexpress and Banggood are not good enough.
I just wanted to ask the community if they knew of any sites or vendors that might sell bulk USB cable and connectors.
Thank you all!
Offline Little4Real
Re: Where to buy parts to make custom usb cables
« Reply #1 on: Sun, 25 November 2018, 17:21:03 »
Checkout Zap Cables and 1up Keyboards. They're usually where I get my USB Parts from. If in a pinch, you can always try eBay or Amazon.
Offline TheGlyph
« Reply #2 on: Thu, 29 November 2018, 03:01:38 »
In the world of electrical engineering Digikey and Mouser are the two main go-to's for electrical components
Instagram @GlennTheBlack
Discord TheGlyph#8458
Offline Pitrek
  • deskpads gallery
    • deskpads gallery
« Reply #3 on: Sat, 01 December 2018, 16:31:46 »
I used to make cables. Have a lot of unused parts. Send me PM if you would like to buy some USB connectors, Techflex sleeving, heatshrinks and cable. At very reasonable price of course.  ;)
