Author Topic: BIG PROJECT --> Copied over from Mods Section  (Read 2108 times)
Offline nads93uk
« on: Thu, 06 May 2010, 15:10:48 »
Hi everyone,
I wanted to make/(heavily mod) a keyboard and I need some help.
Ideally this is how it would turn out:
Start with a clicky (Fukkas/Blues) JIS keyboard (Left-handed?)
Shorten Left Shift
Move Backslash & Underscore from to where a backslash on a European Keyboard would be
Big Backspace!!!
Move �Right Shift Slightly Leftwards to accommodate ¥ sign to the right of it
Reversed L-Enter IMPORTANT: TO MAKE ROOM FOR ALL CHARS, MUST BE APPLE STANDARD (M0116) TYPE ENTER WITH 1-KEY TOP and LONG BOTTOM.
Move Japanese ]}」symbols to 3 places right of P.
Fin
Is there a platform I can start from? Any suggestions?
I will try to illustrate soon.
THANK YOU ALL.
Can I mix and match switches on the same board? Fukkas/MX
Offline nads93uk
« Reply #1 on: Thu, 06 May 2010, 15:28:38 »
i got a (pretty nice) part time job, so my "budget" will be about 350 pound (no pound sign on filco) so and i wanna dedicate some time to this.
Offline nads93uk
« Reply #2 on: Thu, 06 May 2010, 16:09:38 »
Quote from: ripster;179577
Well..... take a look at the Nostromo N52 mod.
P.S.  Why did you move the post here?  ItlnStln is like Ceiling Cat.  Watching us.... you know.
no one gave me a well, feasible answer cos probably no-one saw the damn thing.
I have a filco zero jp model i thought i could (advise me):
  • Find a ISO Filco Left Shift
  • a BIG L enter
  • then swap things around
  • and initiate spagetti wiring
Possible?
Offline nads93uk
« Reply #3 on: Thu, 06 May 2010, 17:15:27 »
Quote from: ripster;179583
No.   See the layout of that section.
does it make a difference whether ive got a Jap layout and a tenkey? cos that looks like the tenkeyless to me.
I did this with a rubber dome to swap alt and meta, just cut off a bit of the circuit and use some wire to solder the different positions.
Offline nads93uk
« Reply #4 on: Thu, 06 May 2010, 17:24:17 »
Quote from: ripster;179608
I still like BH's suggestion better.
Plus, that way you'll have a keyboard Webwit doesn't have.
Lol envy games,
I believe there is an issue of actually somehow finding and buying these items
