Author Topic: Laser Etched PBT keycaps on Poker3 after 4 months use!!  (Read 7410 times)
Offline toty_mk
« on: Sat, 01 December 2018, 11:46:09 »
Look at those CTRL + A + SHIFT keycaps!
I tried to clean them up with some water but it didn't work, any suggestions?
208159-0
208161-1
Thx!
Offline Sup
Re: Laser Etched PBT keycaps on Poker3 after 4 months use!!
« Reply #1 on: Sat, 01 December 2018, 16:39:34 »
Nothing works on those. same key caps they get darker overtime with use.
current
Coming soon
Offline toty_mk
« Reply #2 on: Sun, 02 December 2018, 11:54:58 »
Yeah I've been told that over reddit! New to meks so I thought paying $126 for a keyboard would spare me this kind of troubles. Should've thought better of it! Next time Im gonna grab some doubleshots!
Thx m8!
« Last Edit: Sun, 02 December 2018, 11:57:35 by toty_mk »
Offline Dr_D
« Reply #3 on: Mon, 03 December 2018, 11:58:54 »
Funny you should mention that because the Razer huntsman which retails at $200 also used thin laser etched caps. In addition to doubleshots, PBT dye subs won't fade either.
Offline JPVann
« Reply #4 on: Mon, 07 January 2019, 10:30:11 »
It’s the reason I bought the Pok3r Limited Edition version.  Full aluminum case with acrylic light band and double shot PBT keycaps that are very nice.
