Author Topic: Changing PCB On Model M ?  (Read 1668 times)
Offline Dirty Bint
« on: Fri, 07 May 2010, 16:16:12 »
Hi,
I wish to change the PCB board for a Model M but am not 100% sure of the correct way to remove the plastic templates from the board.
Do the 2 plastic heads pull off the board, I have had a slight tug at them and they seem tight. I know that the plastic template itself will come out of the plastic heads but am not sure if this is the correct way to remove the PCB ?
Rgds
Dirty Bint
I\'m so filthy, I\'m disgusting.
Offline Dirty Bint
« Reply #1 on: Sat, 08 May 2010, 02:15:04 »
I am not sure if I asked my original question in the best way.
On the PCB, I have 2 black connectors, J3 and J4, and each of these has internal contacts. My question is, are these black connectors soldered or fixed to the board or do they come off. I know that I can remove the keyboarb plastic template connector tabs from these black connectors but what I want to know is if the black connectors are meant to be removed as they seem stuck ?
Thx
Dirty Bint
Offline brkz
« Reply #2 on: Sat, 08 May 2010, 03:48:31 »
The black connectors stay put, the plastic ribbon can just be wiggled out gently (and reinstalled the same way)
