Author Topic: Re-silencing FC660C?  (Read 2223 times)
Offline Justintoxicated
« on: Tue, 04 December 2018, 18:00:24 »
Since my keyboard needs to have the plate repainted.  I might as well give it an upgrade if I am going to go through that hassle.
What is the best way to silence my FC660C for under $100?
I have been using dental bands but they were all broken when I took it apart.  I was very happy with their performance while they lasted, but I want something more permanent.
Offline exitfire401
  • The Force is Re/\l
Re: Re-silencing FC660C?
« Reply #1 on: Tue, 04 December 2018, 18:24:09 »
My personal favorite method is still 02dazone. Get a sheet of silicone and some leather punches and go nuts. I think it cost $27 between the rubber and a nice cheap set of leather punches and feels/sounds as good as stock Topre silencing.
« Reply #2 on: Wed, 05 December 2018, 12:52:40 »
what punches?  Where do I buy the silicon?
Offline The_judge_168
« Reply #3 on: Wed, 05 December 2018, 13:49:17 »
Think this is the best bet under $100: https://kbdfans.cn/products/topre-keyboard-silence-x-120pcs
It's about 75% of what purple sliders do for me
Offline Hyde
  • White Tofu Extraordinaire
« Reply #4 on: Wed, 05 December 2018, 20:46:33 »
Personally I've tried the Hypersphere rings and KBDFans rings both has their pros and cons.  However given the price and the pros I think KBDFan rings is your best bet lol.
But effectively Hypersphere dampen better but too thick reduce tactility and KBDFans doesn't reduce tactility but doesn't dampen as well either.  Though both are still better than stock.
