Author Topic: anne pro 2 keycaps  (Read 9168 times)
Offline goodvibes
anne pro 2 keycaps
« on: Fri, 07 December 2018, 12:34:45 »
Hello, i am  new to this forum , and well mechanical keyboards in general.
I have just ordered an anne pro 2 and have been looking all over the net for compatible keycaps for this board.
To be honest i am struggling to find a website that sells either a full 61 keycap set or individual keycaps that will fit the anne pro 2.
Ideally i would like to design my own layout with different colors, hoping to get two or more full colored keysets and mix match the theme?
Can anybody point me in the right direction?
Goodvibes
Offline Sup
Re: anne pro 2 keycaps
« Reply #1 on: Fri, 07 December 2018, 15:03:50 »
WASD keyboard lets you print your own keycaps and you can find great ones aliexpress for cheap. Anne pro got's a standard layout so you can use any standard key set you find online and only use the 60% part. Only problem with that is the ESC keycap that is a different profile.
current
Coming soon
Offline husseinmsaab
    • Moudii Mechanical Keyboards
« Reply #2 on: Thu, 10 January 2019, 17:22:02 »
www.moudiimk.com 2 or more colors for you to choose from. Theyll fit the anne pro 2 100%
Offline Hyperdimension
« Reply #3 on: Fri, 11 January 2019, 10:36:46 »
Anne Pro 2 has a standard layout. 104 key sets and  87 key sets will fit it.
